  2. Hardware/Software Co-Development, Verification…
  3. Regarding Coverage excluding a module
  • Subscribers 49
  • Views 25787
Mohan P
Mohan P over 13 years ago
Hi i am Mohan
I am running, coverage report,, when i it is completed and the coverage report is showing covering all modules.
But i don't need some of modules to be covered which this i can improve coverage report.
I have entered like this to :
deselect_coverage -module -betsa file_name.v  in iccr.key file.
but while doing so it is not showing any coverage improvement.
Please plese can any help out.
  • StephenH
    StephenH over 13 years ago
    Mohan, iccr.key is a file generated by iccr, logging all the interactive commands that you typed.
    Try putting those commands into a Tcl file with some different name like iccr.tcl that won't get overwritten by iccr.
    In addition, the deselect_coverage command takes a list of module names, but you gave it a file name...
  • Mohan P
    Ok Thanks for your reply.
    Please help  me to sort out this issue.
    Ex: There are a.v,b.v & c.v files in one Top_module.v
    then the coverage will be around 80%. To improve the coverage then any one (a/b/c.v) file,  if we want to remove from coverage.
    What will be the command to deselect any (a/b/c.v) files and how to use and where to be used to improve coverage.
    Please help to sort out this problem.............................
    With Regards,
    Mohan P
  • StephenH
    Mohan, deselect_coverage works only on modules or instances, not on file names.
    You can use iccr or imc to manually exclude blocks of code, but that uses the GUI or the "mark" command in Tcl. Look at the section on "Manual Marking of Coverage" in the cdnshelp documentation tool for more detail on that.
    Another possibility is to use the pragma "coverage off" inside the verilog code to turn off coverage. For example:
    // top_module.v
    module top ();
    // pragma coverage off
    `include "a.v"
    // pragma coverage on
    endmodule
  • hellohi
    hellohi over 13 years ago
    I have a doubt, whether its possible to view the excluded list(refinement list) in the coverage HTML report generated using IMC ? Please help on this
