  2. Hardware/Software Co-Development, Verification…
  3. Resolver Model PSpice
  • Subscribers 49
  • Views 17463
Cpereira
Cpereira over 13 years ago
I am simulating a front-end for an electronic system at pspice.
The sensor that I want to use is a Resolver.
Does someone knows how can I find (or in the latest build..) a model / library for a Resolver, so I can simulate my circuit in Orcad Pspice.
Thanks in advance.
Regards
  • Alok Tripathi
    Alok Tripathi over 13 years ago
    resolver model is added in 16.6 release and you can find this model under anl_misc library. Symbol library install location is <INSTALLDIR>/tools/capture/library/pspice/anl_misc.olb
    Simulation model for same can be found in corresponding model library at tools//pspice/library/anl_misc.lib
    Details about this model can be found under resolver chapter of "PSpice Library Models Data Book" . This book is located at <INSTALLDIR>/doc/pspmdlappn/pspmdlappn.pdf
  • Cpereira
     Thanks for you quick reply.
     Unfortunately, I am using the16.3 version. And I checked and it doesn't have the model and the documentation.
    Can you please tell me how can I solve this?
    Carlos
  • Alok Tripathi
    This model and model documentation is not available in 16.3. You need to upgrade to newer version.
