  2. Hardware/Software Co-Development, Verification…
  3. Need help....about schematic and foot print
  • Subscribers 49
  • Views 15083
NEPDEEP
NEPDEEP over 13 years ago
Hi, I can place the components form the list of library available...but now when i try to export the netlist...they say that they are missing the foot print...dont thay come attached with the library ...i mean the original orcad linbrary...or do i need to add footprints to the schematic symbols from somewhere elese...please provide me some hints
  • oldmouldy
    oldmouldy over 13 years ago
    As a trivial example, a given resistor value could have many footprints, since you placed a "generic" resistor and gave it a value, there is no way that Capture could assume a footprint. Specify the Value of the PCB Footprint property in the schematic. For the purposes of experimentation, use the footprints defined in share\pcb\pcb_lib\symbols of the installation, if you need some more specific requirements you will need to design some footprints - for PCB Editor see the algrolibdev.pdf in the doc\algrolibdev directory in the installation.
