  2. Hardware/Software Co-Development, Verification…
  3. HOWTO - CtoS - Identify Write Ops(Specify Micro-architecture...
  • Subscribers 50
  • Views 2039
HOWTO - CtoS - Identify Write Ops(Specify Micro-architecture) in Source Code?
Ahmad Obeid
Ahmad Obeid over 13 years ago
Hi all,
I'm currently in the process of refining a design code with regard to Specify Micro-architecture.
The design code is relatively complex and according to "Specify Micro-architecture" certain arrays have more than one write ops which basically means that there exist multiple writes in one clock.
However, identifying these write ops isn't straight forward.
Question:
- Is there a way in CtoS tool to pin-point the exact write ops in the source code?
 Thanks in advance for your help and cooperation.
Best Regards
Ahmad Obeid
  • Jack Erickson
    Jack Erickson over 13 years ago
    Hi Ahmad,
    Sorry I missed this - there is a High-Level Synthesis forum located here which would be a better place for this:
    /forums/90.aspx
    This forum is for hardware-software verification.
    Anyway, to answer your question, the easiest way to do this is to bring your design up in the GUI ("ctos -gui"), bring up the Control-Data Flow Graph (CDFG), then right-click on the background area of the process you are interested in, and it will bring up a search dialog. You can search by name for all Ops, Array Ops, IO Ops, etc.
    -Jack
  • Ahmad Obeid
    Hi Jack
    Thanks for your reply. After testing, this answers my question.
    Best Regards
    Ahmad Obeid
