  2. Hardware/Software Co-Development, Verification…
  3. Multiple Design Available -Cadence Compiler Error!
  • Subscribers 49
  • Views 2050
venky27
venky27 over 13 years ago
Hi.. Am using cadence to synthesise my design...
I'm getting the following error...
''Error : Multiple designs are available. Specify the design you want to use. [TUI-17] [define_clock]
: There is no unique design available
: Specify a design by using the cd command to change to that design's directory or specify the design as an argument for the command.
Error : Multiple designs are available. Specify the design you want to use by either using the cd command to go to the design directory or use the define_clock ?define option. [TUI-221] [define_clock]
: No unique design.
: You can specify a design by cd'ing into that design's directory, or by using the -design option of define_clock.''
Anyone know the solution for it? Very urgent
Thanks!!
