  2. Hardware/Software Co-Development, Verification…
  3. Fixed step size
  • Subscribers 49
  • Views 16725
Fixed step size
TLIG
TLIG over 13 years ago
Good day evryone
can you told me how to simulate with a fixed the step size  ?
in my simulation i use the MOSFET commutation and with maximum step size ORCAD variate the step size in commutation. But i need  fixed step size.
thank'you
tlig
  • Alok Tripathi
    Alok Tripathi over 13 years ago
    PSpice let you choose maximum time step size for transienet analysis. This is an optional argument. If this argument is defined, simulator would not exceed this limit, however it can go below this, if circuit demands so.
    To set the maximum step limit, in OrCAD Capture, select PSpice>Simulation Setting >Analysis TAB , under Time Domain (transient) Analysis Type, define the "Maximum step size" value.
    Be careful with value, a very small value would slowdown the simulation and generate huge data. Defining this value would also lead to different result vis-a-vis the case when this simulation parameter is not defined. Although generally both of these would be in broad agreement with each other.
  • TLIG
    Thunk'you for answer, but i asked can i work with fixed step size, my problem is to compare a simulation signal and mesurment signal.
    in the mesurment i use a fixe step size in all commutation but wen i use orcad to simulate the sime circuit i have a problem that the step size can be modifie with orcad
    thank'you
    TLIG
