  2. Hardware/Software Co-Development, Verification…
  3. PSpice: coax cable models
  • Subscribers 49
  • Views 19572
PavelM
PavelM over 13 years ago
As far as I've checked, coax cable models in PSpice (TLine.lib library file, which could be open in any ASCII editor) have some definition which looks strange for me. At least, I don't understand where it came from. For example, for RG58C/U coax cable, for its both .model and .subckt options the model series resistance is defined as "r={63.9098u*sqrt(2*s)}". This resistance is intended to model the skin effect losses, which is proportional to sqrt(s).
Later on in the model we can find the commented line with following "r={63.9098u*sqrt(PI2*frq)}". Here it is proportional to sqrt(2*pi*freq), which is a sqrt(s).
Exactly the same file exists in the pre-ORCAD version - MSim.
My question is why it is proportional to sqrt(2*s) in the active model and not to sqrt(s)? Where this factor 2 came from - mathematically / physically?
Sincerely
Pavel
  • Alok Tripathi
    Alok Tripathi over 13 years ago
    In tline library, each co-axial cable (RG58C/U) has two simulation model implementation
    One in form of .Model and other in form of .SUBCKT, which uses fixed frequency for model. depending upon how instance parameters in your schematic, one of these model implementation would be picked up.
    In both case R is function of SQRT(Frequency); i.e you should get similar attenuation/phase shift for both of these and both of these are active models.
    Hope this clarifies.
  • PavelM
     You've explained why there are two types of model for each coax cable.
    My question is different.
    Below is a model of RG58C/U from the TLine.lib file:
    *             Z0(Ohms)  vp(%)  F1(MHz) Loss1(dB/100Ft) F2(MHz)  Loss2(dB/100Ft)
    * RG58C/U        50       66      100       4.9      1000        20
    .model RG58C/U  TRN (r={63.9098u*sqrt(2*s)} l=252.700n
    +   g={0.1584230p*abs(s)}   c=101.08p)
    * Subckt version uses fixed frequency, frq, to model simple lossy line
    *                  Near end hi
    *                   |  Near end lo
    *                   |   |  Far end hi
    *                   |   |   |  Far end lo
    .subckt RG58C/U    A1  A2  B1  B2 params: frq=100Meg len=1
    .param PI2 {3.141592654*2}
    *.model RG58C/U  TRN (r={63.9098u*sqrt(PI2*frq)} l=252.700n
    *+   g={0.1584230p*PI2*frq}   c=101.08p)
    t A1 A2 B1 B2 rg58c/u len={len}
    .ends
    In line 3 of the model above, one can find following definition of R: r={63.9098u*sqrt(2*s)}
    Why it is proportional to (2*s) and not to (s), as it should be for "simple" skin effect? What is a physical explanation of it? Where this coefficient 2 came from?
    Sincerely
    Pavel
  • Alok Tripathi
    I can not think of "physical" explanation for "2". R should be function of "SQRT(S)". To me physical interpretation still remain same even if I say "SQRT(2s)". R remains proportional to SQRT(s), however proportionality constant changes in both cases. Hope this clarifies.
