  2. Hardware/Software Co-Development, Verification…
  3. Fixed Step Size in Orcad Capture
  • Subscribers 49
  • Views 18300
Jothi86
Jothi86 over 13 years ago
 Dear designers,
I have to add noise to my circuit analysis. Since, Pspice do not have the noise source, I have used  "VPWL_F_RE_FOREVER".
In this i have given a input data file containg the data of gaussian white noise generated  using matlab. Now the problem is,
I have a data with equally spaced step size. say for example 1ms. I set "Start saving data=0, TSTOP=20m,maximum step size=1m" .
While the simulation, the psice takes nonuniform step size for the simulation. In this situation, suppose if i have the noise data for 0m, 1m,2m and so on... Between the two succesive time step the pspice generates few new steps as its own. But I strictly need the simulation with the time step used in the input data file.
Can any one please help me in this regard?
 Cheers,
Jothi
  • oldmouldy
    oldmouldy over 13 years ago
    SPICE simulators use an internal algorithm to determine the Minimum Step Size, this cannot be determined by simulator settings. Whilst your input data may have fixed time interval data points, linear interpolation will be used between those points so your input wlll be changing, the circuit state will be changing and PSpice will run the simulation to evaluate the effect of those changes.
  • Jothi86
     Dear Sir,
     I accept your point. But one thing is not clear for me. Since we have to study the effect of noise on a particular circuit, we should have to add a noise data to each iteration. Right? If so then how to do it in orcad?
    Jothi
