  2. Hardware/Software Co-Development, Verification…
  3. Orcad 16.5 dsn to orcad 9.1 version
  • Subscribers 49
  • Views 16825
pramodbv
pramodbv over 13 years ago
Hi friends,
I am having Orcad 16.5 capture and Orcad 9.1 Capture two software, i m not able to view orcad 16.5 dsn file in orcad 9.1version.
Can anybody give me the solution for this problem.
Thanks and Regards
pramod
  • oldmouldy
    oldmouldy over 13 years ago
    In 16.5, select the DSN file in the Project Manager window, File>Save As, change the "Save As Type" to 16.2 DSN, that's as close to a 9.1 format as you can get. Be aware that 9.1 "passed on" as a supported version in September 2000!
  • pramodbv
    hi,
    Already i was  try that one  but not use, is there any possibilites
    thanks in advance.
    Pramod
  • oldmouldy
    Realistically no. The Save As 16.2 should cover it, if it doesn't, I can't see that there will be a lot of effort put into maintaining compatibility with a version that has not been supported for around 13 years now.
