  2. Hardware/Software Co-Development, Verification…
  3. nc_mirror
  • Subscribers 48
  • Views 14812
nc_mirror
livid
livid over 13 years ago
 Hello
The SOC Test chip we are designing has numerous embedded RAMs. We use an on-chip BIST controller for testing the RAMs.
Currently i am trying to test one of the RAMs by simulating a s-a-{0,1} fault.
 Previously we did this using the force command from ncsimrc file.
However, i was given a recommendation that i could use nc_mirror command to access the internal RAM signals and then define a test bench register to drive these nc_mirrored indivual RAM input/outputs to emulate the s-a- fault.
My question being: is the above possible (ie using nc_mirror to access the internal RAM signals and then using a test bench register to drive those nc_mirrored signals to emulate the s-a fault(s))?
Thanks in advance
JO
