  2. Hardware/Software Co-Development, Verification…
  3. use of nc_force, nc_release in a clocked process in the...
  • Subscribers 49
  • Views 18429
use of nc_force, nc_release in a clocked process in the TB
livid
livid over 13 years ago
 Hello
I wondered if it is possible to use nc_force, nc_release in a clocked process in the test bench.
for example, the code i was thinking of was;
process (clk)
begin
    if(test_bench_signal = '1'I then
         nc_force("destination, value);
    else
        nc_release("destination")
    end if;
end
Is the avove code valid and will it work?
  • zoombarabar
    zoombarabar over 11 years ago
    the code will work.
    But you have to understand the idea behind "forcing" the signals and "assigning" the value to signals.
    V.
