  2. Hardware/Software Co-Development, Verification…
  3. PSpice magnetics.lib
  • Subscribers 49
  • Views 18339
Mescheltana
Mescheltana over 12 years ago
The entries in this lib have the form "core type, core size, material". In the application note  "FlowCAD_AN_PSpic_BH_Curve.pdf" one entry is described in detail. I am searching for details of the other entries of this lib. Projects which uses this lib would be even helpfull.
  • Alok Tripathi
    Alok Tripathi over 12 years ago
    Core type - represent the shape of core - U or E or toroid etc.
    material is magnetic material grade ex: 3C85, 3C90 ferrite material grade from ferroxube and other
    Core size represents the physical dimension of core as mentioned in data sheet.
    U93_76_30_3C90 is FERROXCUBE - U93/76/30-3C90 - FERRITE CORE, U shape, 3C90 material. Datahsheet search on Google for this part led me to http://www.farnell.com/datasheets/1595856.pdf
    Also attached a testcase showing simulation using one such magnetic core for various applications.
    magnetics.zip
  • Mescheltana
    I have installed the project. I have used the magnetics.olb. For the modification of the model with the model editor I find the advise in the application note:
    The BH curve of the same magnetic core can also be plotted in Model Editor. To do so, save
    the model in a PSpice library e.g. core_bh.lib and then open it using Model Editor.
    How can I generate this .lib from the model contained in the magnetic.olb ?
  • Alok Tripathi
    Follow the steps:
    Place appropriate part(core in this case) into schematic
    Select the core symbol and do RMB>Edit PSpice Model
    Tool will create a copy of Model in <designname>.lib file and open the same in model editor. If model is already present in <designname>.lib or other lib configured at design level would be opened up. In any case you get a local copy of model.
    Or
    launch Model Editor
    Create a new lib
    Select Model>Copy from
    Browse to magnetics.lib under source library, Select appropriate core model from list of model present in magnetics.lib and give new name to Model and copy of same would be placed in new lib.
     Hope this helps.
