  2. Hardware/Software Co-Development, Verification…
  3. error after including bondpads in design
  • Subscribers 49
  • Views 14862
Sss19
Sss19 over 11 years ago
I am using IC615 with LFoundry. I was easily simulating my design but when I added bonpads, I got the following errors. Any suggestion of why they are appearing? I am asking here as I think that the error are related to software installation.
Cadence (R) Virtuoso (R) Spectre (R) Circuit Simulator
Version 12.1.1.048 32bit -- 4 Jun 2013
Copyright (C) 1989-2013 Cadence Design Systems, Inc. All rights reserved worldwide. Cadence, Virtuoso and Spectre are registered trademarks of Cadence Design Systems, Inc. All others are the property of their respective holders.
Includes RSA BSAFE(R) Cryptographic or Security Protocol Software from RSA Security, Inc.
User: sana Host: CadenceLatest HostID: 7F0200 PID: 19524
Memory available: 3.1475 GB physical: 4.7660 GB
CPU Type: Intel(R) Core(TM) i7-2630QM CPU @ 2.00GHz
Processor PhysicalID CoreID Frequency
0 - - 2150.3
Simulating `input.scs' on CadenceLatest at 7:01:53 AM, Fri May 15, 2015 (process id: 19524).
Current working directory: /home/sana/simulation/Testbench_36/spectre/schematic/netlist
Command line:
/usr/local/cadence/installs/MMSIM121/tools/spectre/bin/32bit/spectre \
input.scs +escchars +log ../psf/spectre.out +inter=mpsc \
+mpssession=spectre0_17385_1 -format psfxl -raw ../psf \
+lqtimeout 900 -maxw 5 -maxn 5
spectre pid = 19524
Loading /usr/local/cadence/installs/MMSIM121/tools.lnx86/cmi/lib/5.0/libinfineon_sh.so ...
Loading /usr/local/cadence/installs/MMSIM121/tools.lnx86/cmi/lib/5.0/libphilips_o_sh.so ...
Loading /usr/local/cadence/installs/MMSIM121/tools.lnx86/cmi/lib/5.0/libphilips_sh.so ...
Loading /usr/local/cadence/installs/MMSIM121/tools.lnx86/cmi/lib/5.0/libsparam_sh.so ...
Loading /usr/local/cadence/installs/MMSIM121/tools.lnx86/cmi/lib/5.0/libstmodels_sh.so ...
Reading file: /home/sana/simulation/Testbench_36/spectre/schematic/netlist/input.scs
Reading file: /usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150rf.scs
Reading file: /usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150rf_mosrf_hs.scs
Reading file: /usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150rf_mosrf_ll.scs
Reading file: /usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150rf_mosrf_3.scs
Reading file: /usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150rf_nvarrf.scs
Reading file: /usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150rf_resrf.scs
Reading file: /usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150rf_mimrf.scs
Reading file: /usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150rf_ind.scs
Reading file: /usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150.scs
Reading file: /usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_hs.scs
Reading file: /usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_res.scs
Reading file: /usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mim.scs
Reading file: /usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_dio.scs
Reading file: /usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_bjt.scs
Reading file: /usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs
Time for NDB Parsing: CPU = 100.005 ms, elapsed = 604.907 ms.
Time accumulated: CPU = 100.005 ms, elapsed = 604.907 ms.
Peak resident memory used = 25.4 Mbytes.
Warning from spectre in `nmosrf_hs', during circuit read-in.
WARNING (SFE-57): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150rf_mosrf_hs.scs" 22: Parameter name `m' is reserved for the subcircuit multiplicity factor. So a formal parameter of that name is ignored.
Warning from spectre in `pmosrf_hs', during circuit read-in.
WARNING (SFE-57): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150rf_mosrf_hs.scs" 394: Parameter name `m' is reserved for the subcircuit multiplicity factor. So a formal parameter of that name is ignored.
Reading link: /usr/local/cadence/installs/MMSIM121/tools.lnx86/spectre/etc/ahdl/discipline.h
Reading file: /usr/local/cadence/installs/MMSIM121/tools.lnx86/spectre/etc/ahdl/disciplines.vams
Reading link: /usr/local/cadence/installs/MMSIM121/tools.lnx86/spectre/etc/ahdl/constants.h
Reading file: /usr/local/cadence/installs/MMSIM121/tools.lnx86/spectre/etc/ahdl/constants.vams
Opening directory input.ahdlSimDB/ (775)
Opening directory input.ahdlSimDB//bsource.va.bsource_3.ahdlcmi/ (775)
Opening directory input.ahdlSimDB//bsource.va.bsource_3.ahdlcmi/Linux/ (775)
Compiling ahdlcmi module library.
Finished compilation in 1.02 s (elapsed).
Installed compiled interface for bsource_3.
Opening directory input.ahdlSimDB//bsource.va.bsource_1.ahdlcmi/ (775)
Opening directory input.ahdlSimDB//bsource.va.bsource_1.ahdlcmi/Linux/ (775)
Finished compilation in 984 ms (elapsed).
Installed compiled interface for bsource_1.
Opening directory input.ahdlSimDB//bsource.va.bsource_2.ahdlcmi/ (775)
Opening directory input.ahdlSimDB//bsource.va.bsource_2.ahdlcmi/Linux/ (775)
Finished compilation in 982 ms (elapsed).
Installed compiled interface for bsource_2.
Opening directory input.ahdlSimDB//bsource.va.bsource_4.ahdlcmi/ (775)
Opening directory input.ahdlSimDB//bsource.va.bsource_4.ahdlcmi/Linux/ (775)
Finished compilation in 993 ms (elapsed).
Installed compiled interface for bsource_4.
Opening directory input.ahdlSimDB//bsource.va.bsource_5.ahdlcmi/ (775)
Opening directory input.ahdlSimDB//bsource.va.bsource_5.ahdlcmi/Linux/ (775)
Finished compilation in 994 ms (elapsed).
Installed compiled interface for bsource_5.
Error found by spectre in `nmos_ll':`I15.I27.I4.M0', in `lf150_pio1v8Lib_ll_1v8_p_vss_io_ac_ll_schematic':`I15.I27.I4', in `lf150_pio1v8Lib_ll_1v8_p_vss_io_ac_80u_ll_schematic':`I15.I27', in `sid_47_schematic':`I15', during hierarchy flattening.
ERROR (SFE-1999): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 23: Model `I15.I27.I4.M0.nmos_ll': parameter `tox': Unknown parameter name `delta_n_tox_ll' found in expression.
ERROR (SFE-1999): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 23: Model `I15.I27.I4.M0.nmos_ll': parameter `vth0': Unknown parameter name `delta_n_vth0_ll' found in expression.
ERROR (SFE-1999): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 23: Model `I15.I27.I4.M0.nmos_ll': parameter `nlx': Unknown parameter name `delta_n_nlx_ll' found in expression.
ERROR (SFE-1999): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 23: Model `I15.I27.I4.M0.nmos_ll': parameter `dvt0': Unknown parameter name `delta_n_dvt0_ll' found in expression.
ERROR (SFE-1999): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 23: Model `I15.I27.I4.M0.nmos_ll': parameter `u0': Unknown parameter name `delta_n_u0_ll' found in expression.
ERROR (SFE-1996): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 19: Parameter `ua_mis': Unknown parameter name `uanll_mis' found in expression.
ERROR (SFE-1999): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 23: Model `I15.I27.I4.M0.nmos_ll': parameter `lint': Unknown parameter name `delta_n_lint_ll' found in expression.
ERROR (SFE-1999): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 23: Model `I15.I27.I4.M0.nmos_ll': parameter `cj': Unknown parameter name `delta_n_cj_ll' found in expression.
ERROR (SFE-1999): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 23: Model `I15.I27.I4.M0.nmos_ll': parameter `cjsw': Unknown parameter name `delta_n_cjsw_ll' found in expression.
Error found by spectre in `nmos_ll':`I15.I27.I4.M1', in `lf150_pio1v8Lib_ll_1v8_p_vss_io_ac_ll_schematic':`I15.I27.I4', in `lf150_pio1v8Lib_ll_1v8_p_vss_io_ac_80u_ll_schematic':`I15.I27', in `sid_47_schematic':`I15', during hierarchy flattening.
ERROR (SFE-1999): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 23: Model `I15.I27.I4.M1.nmos_ll': parameter `tox': Unknown parameter name `delta_n_tox_ll' found in expression.
ERROR (SFE-1999): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 23: Model `I15.I27.I4.M1.nmos_ll': parameter `vth0': Unknown parameter name `delta_n_vth0_ll' found in expression.
ERROR (SFE-1999): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 23: Model `I15.I27.I4.M1.nmos_ll': parameter `nlx': Unknown parameter name `delta_n_nlx_ll' found in expression.
ERROR (SFE-1999): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 23: Model `I15.I27.I4.M1.nmos_ll': parameter `dvt0': Unknown parameter name `delta_n_dvt0_ll' found in expression.
ERROR (SFE-1999): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 23: Model `I15.I27.I4.M1.nmos_ll': parameter `u0': Unknown parameter name `delta_n_u0_ll' found in expression.
ERROR (SFE-1999): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 23: Model `I15.I27.I4.M1.nmos_ll': parameter `lint': Unknown parameter name `delta_n_lint_ll' found in expression.
ERROR (SFE-1999): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 23: Model `I15.I27.I4.M1.nmos_ll': parameter `cj': Unknown parameter name `delta_n_cj_ll' found in expression.
ERROR (SFE-1999): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 23: Model `I15.I27.I4.M1.nmos_ll': parameter `cjsw': Unknown parameter name `delta_n_cjsw_ll' found in expression.
Error found by spectre in `nmos_ll':`I15.I27.I4.C5', in `ccapn_l':`I15.I27.I4.C5', in `lf150_pio1v8Lib_ll_1v8_p_vss_io_ac_ll_schematic':`I15.I27.I4', in `lf150_pio1v8Lib_ll_1v8_p_vss_io_ac_80u_ll_schematic':`I15.I27', in `sid_47_schematic':`I15', during hierarchy flattening.
ERROR (SFE-1999): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 23: Model `I15.I27.I4.C5.ccapn_l.nmos_ll': parameter `tox': Unknown parameter name `delta_n_tox_ll' found in expression.
ERROR (SFE-1999): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 23: Model `I15.I27.I4.C5.ccapn_l.nmos_ll': parameter `vth0': Unknown parameter name `delta_n_vth0_ll' found in expression.
ERROR (SFE-1999): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 23: Model `I15.I27.I4.C5.ccapn_l.nmos_ll': parameter `nlx': Unknown parameter name `delta_n_nlx_ll' found in expression.
ERROR (SFE-1999): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 23: Model `I15.I27.I4.C5.ccapn_l.nmos_ll': parameter `dvt0': Unknown parameter name `delta_n_dvt0_ll' found in expression.
ERROR (SFE-1999): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 23: Model `I15.I27.I4.C5.ccapn_l.nmos_ll': parameter `u0': Unknown parameter name `delta_n_u0_ll' found in expression.
ERROR (SFE-1999): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 23: Model `I15.I27.I4.C5.ccapn_l.nmos_ll': parameter `lint': Unknown parameter name `delta_n_lint_ll' found in expression.
ERROR (SFE-1999): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 23: Model `I15.I27.I4.C5.ccapn_l.nmos_ll': parameter `cj': Unknown parameter name `delta_n_cj_ll' found in expression.
ERROR (SFE-1999): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 23: Model `I15.I27.I4.C5.ccapn_l.nmos_ll': parameter `cjsw': Unknown parameter name `delta_n_cjsw_ll' found in expression.
Error found by spectre in `pmos_ll':`I15.I27.I4.M2', in `lf150_pio1v8Lib_ll_1v8_p_vss_io_ac_ll_schematic':`I15.I27.I4', in `lf150_pio1v8Lib_ll_1v8_p_vss_io_ac_80u_ll_schematic':`I15.I27', in `sid_47_schematic':`I15', during hierarchy flattening.
ERROR (SFE-1999): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 195: Model `I15.I27.I4.M2.pmos_ll': parameter `tox': Unknown parameter name `delta_p_tox_ll' found in expression.
ERROR (SFE-1999): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 195: Model `I15.I27.I4.M2.pmos_ll': parameter `vth0': Unknown parameter name `delta_p_vth0_ll' found in expression.
ERROR (SFE-1999): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 195: Model `I15.I27.I4.M2.pmos_ll': parameter `nlx': Unknown parameter name `delta_p_nlx_ll' found in expression.
ERROR (SFE-1999): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 195: Model `I15.I27.I4.M2.pmos_ll': parameter `dvt0': Unknown parameter name `delta_p_dvt0_ll' found in expression.
ERROR (SFE-1999): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 195: Model `I15.I27.I4.M2.pmos_ll': parameter `u0': Unknown parameter name `delta_p_u0_ll' found in expression.
ERROR (SFE-1996): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 191: Parameter `ua_mis': Unknown parameter name `uapll_mis' found in expression.
ERROR (SFE-1999): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 195: Model `I15.I27.I4.M2.pmos_ll': parameter `lint': Unknown parameter name `delta_p_lint_ll' found in expression.
ERROR (SFE-1999): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 195: Model `I15.I27.I4.M2.pmos_ll': parameter `cj': Unknown parameter name `delta_p_cj_ll' found in expression.
ERROR (SFE-1999): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 195: Model `I15.I27.I4.M2.pmos_ll': parameter `cjsw': Unknown parameter name `delta_p_cjsw_ll' found in expression.
Time for Elaboration: CPU = 384.024 ms, elapsed = 5.41809 s.
Time accumulated: CPU = 484.029 ms, elapsed = 6.02319 s.
Peak resident memory used = 35 Mbytes.
spectre terminated prematurely due to fatal error.
Thanks and Regards,
Sana Arshad
