  2. Hardware/Software Co-Development, Verification…
  3. Need info on variable setting in questDebug
  • Subscribers 48
  • Views 14383
archive over 20 years ago
Hi Amrik,
Just to expand a little bit:
There are several layers in controlling what the user does and in order of importance:
1. The way you leave questDebug GUI is the way you get questDebug back.
You will see that in file .qtProfile. under:
[Newrun]
autoupload=0|1
etc
Then (2nd in importance):
2. If you do like what volker suggested
switch it off in questDebug under File -> User GUI Settings. The result gets stored in .qtProfile..
[UserGUISetting]
autoupload=0|1
etc
Then (3rd in importance)
3) If the user wants to predefine his options globally on a all his designs, he can create ~/.qtProfile
   which is read if there is no .qtProfile. is detected. You can just copy qtProfile. to
~/.qtProfile.
I just tested the above before sending this email.
Loai
Sent: Friday, September 01, 2006 7:43 AM
To: cva_ae
Subject: Need info on variable setting in questDebug
Hi all,
Customer is using questDebug for debug purposes in both LA & STB mode. However he has a query. Is their a way to turn-off the "Auto-Waveform" tab in main window of questDebug by default( this is currently turned-on by default) maybe by doing some enviornment variable setting before running the questDebug.
Thanks & Regards
amrik
Amrik Singh Virdi
Lead AE, Hardware Assisted Verification
Cadence Design Systems
2nd Floor, 3 B Building RMZ Ecospace
Sarjapur Outer Ring Road
Bangalore, 560037, India
Phone: +91.80.4184.1089
Originally posted in cdnusers.org by ashvarma
