  2. Hardware/Software Co-Development, Verification…
  3. Read-Modify-Write using Xtreme Memory Compiler (+mc), Release...
  • Subscribers 48
  • Views 14551
Read-Modify-Write using Xtreme Memory Compiler (+mc), Release 5.3.x
archive over 20 years ago
If you are using or plan to use RMW type of memory operation in RTL and then want to compile memory to Xtreme using +mc, then please keep in mind following-
RMW is typically used to implement bitwise masking in the following way, e.g.
always@(posedge write_clk)
  mem[write_addr]
If you use this style, then the memory generated by MC will be quite complicated, using axis_behctrl and a behavioral statemachine.
Instead, use the following method for achieving the same functionality:
assign write_dout = mem[write_addr];
  mem[write_addr]
The above is correctly transformed to simple axis_smem with one async. read port and a sync. write port. This is easier to debug and faster to simulate.
The above recommendation only applies to a sync. write port.
You can always look at MC generated memories by using +mcdbg switch (which creates AXIS_MC.DEBUG text file) to ensure memories are transformed to their simple axis_smem forms and not having to use axis_behctrl.
-ashutosh
Originally posted in cdnusers.org by ashvarma
