  2. Hardware/Software Co-Development, Verification…
  3. Help with FileStim16
  • Subscribers 48
  • Views 14312
archive over 19 years ago
Hi. Can anyone point me in the right direction on how to use FileStim16.
I’ve connected a bus called data?-15] to the F16 (FileStim) called “data”. Filename = data.stl
Created a stimulus file (data.stl), with a bus called data (16bits wide).
Via PSpice , Edit Simulation Profile ,Configuration Files, (Category Stimulus). And Edit to create the file.
But keep getting the following errors.
ERROR – Unable to find signal DATA1 in stimulus file “data.stl”
This will repeat for all 16 data signals.
Using OrCad version 15.7.
Originally posted in cdnusers.org by neil2007
