  2. Hardware/Software Co-Development, Verification…
  3. Timing Violation Warning
  • Subscribers 48
  • Views 21051
archive over 18 years ago
I have run gate simulation with SDF. I meet the following warning.
Warning!  Timing violation
             Scheduled event for delayed signal of net "D" at time 275093160 PS was candeled!
              File: xxxxxxx line=xxx
              Scope: xxxxx
Can anybody tell me what this mean? I add +notchkmsg but this message still print. Can anybody tell me why?
Thanks!
Originally posted in cdnusers.org by huyong
    Hello Huyong,
    If you are asking what the message means.
    A timing check verifies the timing performance of a design by making sure that critical events occur within given time limits. A timing check performs the following steps:
       1. Determines the elapsed time between two events.
       2. Compares the elapsed time to a specified minimum or maximum time limit.
       3. Reports a timing violation if the elapsed time occurs outside the specified time window.
    If you are asking how to turn the message off:
    I think (but not sure) You can add  +nonotifier +no_tchk_msg to your switches to turn the message off. Please let me know if it works
    Best Regards
    Doug
    Originally posted in cdnusers.org by douge
    Hi Doug
    Thank you for you answer. I the +no_tchk_msg do not turn the message off. I use +ncnontcglitch to turn it off
