  2. Implementation
  3. Simulation of OTA with high input range and load drive capacity...
  • Subscribers 6
  • Views 10949
Simulation of OTA with high input range and load drive capacity to obtain design parameters
Maryjos
Maryjos over 5 years ago
I want to do some simulations to find design parameters for an OTA .
This is for implementing an OTA based active second order low pass filer, to be used in a high speed wide bandwidth PLL
So the OTA should have:
  • high output impedance.
  • should be able to drive a capacitor of about 10-20 pF.
  • should have a large input range
Are there some ideal models available from which I could find the gain bandwidth product, slew rate and gain? Can someone help me understand what should be the design considerations and how the simulations can be done?
