  2. Implementation
  3. Functional coverage: array of covergroups
  • Subscribers 7
  • Views 16529
CK47
CK47 over 5 years ago
Hi
I need to create a array of cover groups. I declared the covergroup in a class and created a array of classes. I used generate block to instantiate the class.
Once I run the tests to get coverage, the IMC tool shows only one instance of the class and covergroup in functional coverage section. How ever there are multiple instances of this covergroup created in code coverage section.
I need multiple instances of the covergroup in functional coverage section.
Below is the code I used -
class cg_wrapper ;
covergroup cg_test with function sample(bit x);
cp_temp: coverpoint x { bins zero_1 = (0=>1);
bins one_0 = (1=>0);}
endgroup
function new (string name = "cg_temp_w");
cg_test = new();
cg_test.set_inst_name(name);
endfunction
function sample (bit x);
cg_test.sample(x);
endfunction
endclass
genvar kk ;
generate for(kk = 0;kk<9;kk++)
begin : cg_test_wrap
cg_wrapper wrapper_inst = new(temp_bit[kk]);
end
endgenerate
  • Diego Manas
    0 Diego Manas over 3 years ago
    Late to the party here, but just in case somebody stumbles upon this. To enable per instance collection, you need to add "option.per_instance = 1;" to your covergroup. Otherwise, all gets collected into the same bucket
