  2. Implementation
  3. uvm Error-[IND] Identifier not declared
  • Subscribers 6
  • Views 9671
rkaur9
rkaur9 over 5 years ago
Hello ,
My code for sequence is follows ,
`ifndef seq_stimulus
`define seq_stimulus
import uvm_pkg::*;
`include "uvm_macros.svh"
class seq_stimulus extends stimulus;
`uvm_object_utils(seq_stimulus)
stimulus req;
function new(string name = "seq_stimulus");
super.new(name);
endfunction
virtual task body();
req = stimulus::type_id::create("req");
`uvm_do(req);
`uvm_info(get_type_name(),$sformatf("data = 'h%0h,valid= 'h%0h",req.data,req.valid),UVM_HIGH)
endtask
endclass
`endif
but it gives error:
/classes_v/seq_stimulus.sv, 20
Identifier 'create_item' has not been declared yet. If this error is not
expected, please check if you have set `default_nettype to none.
seq_stimulus.sv, 20
Identifier 'start_item' has not been declared yet. If this error is not
seq_stimulus.sv, 20
Identifier 'finish_item' has not been declared yet. If this error is not
please suggest thnks
