  2. Implementation
  3. PNR using Innovus
  • Subscribers 12
  • Views 12237
PNR using Innovus
AnithaShrey211
AnithaShrey211 over 4 years ago
What does this command mean set sprCreateIeRingOffset 1.0 in the power planning stage of pnr ?
  • wardrose4
    0 wardrose4 over 4 years ago
    Refer to
    cookie clicker
    Backslashed names will retain backslash and a trailing blank character.
    Reading verilog netlist 'controller_struct.v'
    Module DFF2 not defined. Created automatically.
    **WARN: (ENCVL-346): Module DFF2 is not defined in LEF files. It will be treated as an empty module.
    *** Memory Usage v#1 (Current mem = 631.668M, initial mem = 140.191M) ***
    *** End netlist parsing (cpu=0:00:00.0, real=0:00:00.0, mem=631.7M) ***
    Top level cell is controller.
    *** End library_loading (cpu=0.00min, mem=0.0M, fe_cpu=0.13min, fe_real=0.47min, fe_mem=631.8M) ***
