  2. Logic Design
  3. PLE adjusting in Rtl compiler
  • Replies 13
  • Subscribers 61
  • Views 23207
archive over 19 years ago
Hi guys,
Does anybody know how to adjust PLE setting in RTL compiler so it will be more in line with encounter results?
I heard somebody talk about it, but he is not available now.
Any help would be appreciated.
Manzur.
Originally posted in cdnusers.org by myazdani
    Hi Cristiano,
    I believe I ran into this and ETS6.2-USR1 did support set_load on nets. I have not tried it in SOC so I do not know what version of SOC would incorporate the enhancements to CTE and SOC.
    gh-
    Originally posted in cdnusers.org by grasshopper
    Hi Cristiano,
    write_spef is also supported in RC 7.1. write_sdf/write_spef/write_set_load are commands available in RC to help correlate PLE results with CTE. I haven't done experiments on which method works best.
    write_ets is also available to provide a starter script to run ETS.
    ETS 6.2 USR1 accepts set_load on nets.
    -NC
    Originally posted in cdnusers.org by nandini
    I think set_load will be supported in SOC62USR2 (planned to 08/08/2007).
    I tried the command spefIn using the spef file generated by RC7.1 and it seems be ok.
    Thanks a lot,
    Cristiano.
    Originally posted in cdnusers.org by clsantos
