  2. Logic Design
  3. LEC - confusion with rtl vs netlist
  • Subscribers 62
  • Views 3109
bharat1001
bharat1001 over 14 years ago
Hi, I have a golden RTL. I synthesize this RTL using Synplify and get a netlist, A. Using the VIF flow, I run LEC and find that netlist A and the RTL are equivalent. I then synthesize the same golden RTL using different synthesis options and the same synthesizer and get a netlist, B. LEC shows that netlist B and the golden are not equivalent. I then attempt to LEC netlist A and netlist B expecting mismatches, however LEC says they are equivalent! With respect to unmapped key points, I do have them, but in the golden RTL and both netlists, they are all unreachable. What can cause netlist A and B to be equivalent? Thanks
  • croy
    croy over 14 years ago
    Hi Bharat It's quite common to have rtl-synth1 and rtl-synth2 pass while synth1-synth2 fails (dont-care optimized differently) or aborts (datapath optimized differently). Both netlists are fine, just implemented a little different. I'm scratching my head as to your description of rtl-synth1 and synth1-synth2 passing and rtl-synth2 failing. That's a new one. Can you create a Service Request please so someone looks at the logs? Thanks, Chrystian
