  2. Logic Design
  3. LEC - Conformal RTL to netlist mismatch
  • Replies 11
  • Subscribers 65
  • Views 19161
hnfq
hnfq over 14 years ago
Hi, I have now seen this issue with two different designs and have not been able to figure out the root cause for this behaviour.
I have synthesized a design using RTL Compiler and have generated both mapped and an optimized netlist.
1. When I compare the RTL to mapped netlist (non-hierarchical comparison), I don't see any non-equivalent points.
2. When I compare the mapped netlist to the final optimized netlist, I don't see any non-equivalent points.
3. But when I compare RTL to final optimized netlist, I get non-equivalent points.
Looking into this matter in detail, I noticed that these non-equivalent points start showing up as soon as I run the first incremental synthesis on the mapped netlist.
Any ideas as to why the RTL to final netlist comparison are showing non-equivalencies?
  • grasshopper
    grasshopper over 12 years ago
    unfortunately you do not include enough information for anyone to help you. You should include the schematic showing the nonEQ. You indicate LEC is confuse. Can you shed light why you think LEC is confused and the nonEQ is not real? Better yet, if the circuit is simple as you indicate, I believe the schematic should help you understand the difference and whether it is a real issue, setup issue, or something else.
    hope this helps,
    gh-
