  2. Mixed-Signal Design
  3. Problems with AHDL Block Rand Bit Stream in Cadence Virtuoso...
  • Subscribers 64
  • Views 14371
Problems with AHDL Block Rand Bit Stream in Cadence Virtuoso using Spectre RF
growingmind
growingmind over 7 years ago
I want to measure the Eye Diagram of a Broadband Bipolar amplifier I designed in Cadence Virtuoso using SpectreRF.
When I use Rand Bit Stream - i get a lot of errors and the transistor breaking down at BE junction.
I do not get this error with MOS amplifiers.
What can I do - how can I measure the eye diagram of bipolar transistor properly with rand bit stream ?
Thanks.
    I can't think of any good reason why this would happen unless the signal levels are too high (or low) for the circuit you've designed. Without more info it's hard to comment, so perhaps you should contact customer support.
    I see you posted the same question on the Designer's Guide forums too.
