  2. Mixed-Signal Design
  3. Plotting Ids vs Vgs in Cadence of a transistor - Want Y...
  • Subscribers 64
  • Views 4230
Plotting Ids vs Vgs in Cadence of a transistor - Want Y Axis to be Square Root of IDS
growingmind
growingmind over 7 years ago
Simple question: I want to plot Plotting Ids vs Vgs in Cadence of a transistor  but I  want Y Axis to be Square Root of IDS - how do I plot this in Cadence Virtuoso/Spectre using the ADE and Calculator ?
Thank you.
    Assuming you know how to plot ids vs vgs, simply send the expression  you're using to the calculator and use the sqrt function in the calculator to take the square root of it, and then plot that.
    Andrew/
