  2. Mixed-Signal Design
  3. Import Wavescan waveform (Spectre) in SimVision
  • Subscribers 64
  • Views 19190
pyohayo
pyohayo over 6 years ago
SimVision allows generating VCD files that can be used to apply digital stimuli in Spectre simulations.
I wonder if exist some way to get Spectre waveform back to SimVision for post-simulations checks & analysis.
WaveScan allows diditize waveform, but I didn't find how to export such digitized waveform in any SimVision-compatible format (e.g. vcd)
    Well, this is what happens when  you use a release that came out 15 years ago (I assume from your previous posts plus references to "wavescan" that you must be using IC5141).
    ViVA (the newer waveform tool since IC615) does support export to SST2 and PSFXL which can both be read by SimVision.
    However, in IC5141, the default behaviour is for spectre to run transient simulations and save the results in SST2 format. So you should be able to directly open the "psf" result directory in simvision as a database and plot the transient results that way. Check the spectre log from  your simulation and check that it has "-format sst2" in the command line. If not, you'd have to do:
      envSetVal("spectre.envOpts" "simOutputFormat" 'string "sst2")
    in the CIW and restart the ADE window. As I said, sst2 is the default, so it would only be different if it's been explicitly changed somewhere.
  • pyohayo
    pyohayo over 6 years ago in reply to Andrew Beckett
    Indeed, it works. Thanks Andrew.
    I imported Spectre staff in SimVision, but didn't found how to "digitize" (i.e. a2d) a particular waveform.
    Is it possible ?
  • pyohayo
    pyohayo over 6 years ago in reply to pyohayo
    I've just tried atod function in SimVision:
    atod("tran.tran"::grp1_tr, 0.9, 0.9)
    where grp1_tr - signal I want to digitalize, 0.9 - thershold.
    Doesn't work: "operands have incompatible inputs"
  • pyohayo
    Works.
    atod("tran.tran"::grp1_tr, 0.5 V)
    Andrew Beckett over 6 years ago in reply to pyohayo
    Or you could just select the analog trace in the simVision waveform window, and do Edit->Create->Bus and specify your thresholds (the defaults are on Edit->Preferences). It would then create a single bit bus with the waveform converted to digital.
  • pyohayo
