  2. Mixed-Signal Design
  3. Setup Spectre simulation in batch mode
  • Subscribers 64
  • Views 16464
pyohayo
pyohayo over 6 years ago
How to setup Spectre simulations in batch mode according to the following scenario:
  • circuit - the same for all runs
  • each run use a particular .vcd stimuli
  • once i-th simulation finished, results are saved in a particular folded (for post-processing) ... not to be crushed by i+1 th simulation
I beleive that netlist for each of N cases must be generated in advance, then all these netlists are processed in a loop that should be created somewhere ?
    You could also do this easily with OCEAN:
    vcdfiles=list(list("vcd1.vcd" "vcd1.info") list("vcd2.vcd" "vcd2.info"))
    simulator('spectre)
    design(lib cell view "r")
    analysis(...)
    runNum=1
    foreach(vcdfile vcdfiles
      vcdFile(car(vcdfile))
      vcdInfoFile(cadr(vcdfile))
      resultsDir(sprintf(nil "/path/to/results/vcdResults%d" runNum))
      run()
      runNum++
    Something like that. This is completely untried, but it should work.
  • pyohayo
    pyohayo over 6 years ago in reply to Andrew Beckett
    I tried with Ocean.
    I've sligthle modified your code - I use the same info for 4 .vcd.
    Here is reduced of ocean file (I removed not-relevant sections, e.g. modelFile and definitionFile).
    ocnWaveformTool( 'wavescan )
    simulator( 'spectre )
    design( "path-to-project-directory/simulation/data/slice_test/spectre/schematic/netlist/netlist")
    resultsDir( "path-to-project-directory/simulation/data/slice_test/spectre/schematic" )
    projectDir = "{path-toproject-directory}"
    vcdfiles=list("slow_000.vcd" "slow_111.vcd" "fast_000.vcd" "fast_111.vcd")
    vcdInfoFile(
    "path-to-project-directory/slow_fast.info"
    analysis('tran ?stop "950u" ?errpreset "moderate" )
    desVar( "qin2" 1p )
    desVar( "qin" 58f )
    option( 'maxnotestologfile "1000"
    'maxwarnstologfile "1000"
    'maxwarns "1000"
    'warn "yes"
    'maxnotes "1000"
    option( ?categ 'turboOpts 'uniMode "Turbo"
    saveOption( 'subcktprobelvl "" )
    saveOption( 'nestlvl "4" )
    saveOption( 'save "lvlpub" )
    temp( 27 )
    run()
    runNum=1
       vcdFile(strcat(projectDir vcdfile))
       resultsDir(sprintf(nil "path-to-project-directory/vcdResults%d" runNum))
       run()
       runNum++
    Obviously Spectre did only one run ... but created 4 different directories (vcdResults1 ... vcdResults4) that contain the same data.
    I checked vcdResults1 ... vcdResults4 creation time - they are the same.
