  2. Mixed-Signal Design
  3. Spectre MDL help for "noise" analysis
  • Subscribers 64
  • Views 1958
sn4c
sn4c over 6 years ago
I am running MMSIM 15.10.766.
mdlref.pdf says that MDL supports noise analysis, but I do not see a (good) MDL example for noise analysis in this or other related docs I found.
I am able to run the noise analyis by MDL, but I have not been able to extract, for example, the output noise current parameters.
A sample netlist is attached at the end of this message. Run a simulation, and a .raw file will be generated in the nutmeg ascii format. How do I use MDL to obtain/access, for example, the "out" variable, as shown in the .raw file?
Thanks.
// MOSFET noise
simulator lang=spectre
op_1 options rawfmt=nutascii
model nmos1 bsim4 type=n
m1 (d g s b) nmos1 w=1u l=0.12u
v_probe (d d0) vsource dc=0
vd (d0 0) vsource dc=0.05
vg (g 0) vsource dc=0.5
vs (s 0) vsource dc=0
vb (b 0) vsource dc=0
noise_1 noise oprobe=v_probe iprobe=vg values=[1e3]
  • sn4c
    Got help from Cadence support:
    alias measurement runnoise {
    export real input_noise, output_noise,
    rms_output_noise, rms_input_noise;
    run noise(start=1, stop=1G, dec=10, iprobe=V7, terminals={"OUTP"}) ;
    input_noise = runnoise:in;
    output_noise = runnoise:out;
    rms_output_noise = rmsnoise(runnoise:out);
    rms_input_noise = rmsnoise(runnoise:in);
    export real noise_factor = runnoise:F;
    export real noise_figure = runnoise:NF;
    export real noise_at_freq = (runnoise:out) @ 1k;
    export real avg_noise = avg(runnoise:out);
    export real max_noise = max(runnoise:out);
    run runnoise
    Please refer the section “Running Noise Analysis” in the below provided link for more details with database:
    Advanced SpectreMDL Simulation
    https://support.cadence.com/apex/articleattachmentportal?id=a1O0V000009Mo6NUAS&pageName=ArticleContent&attachId=0690V000006NMrxQAG&sq=null
