  2. Mixed-Signal Design
  3. How to define a current measurement in ADEXL + Montecarlo...
  • Replies 13
  • Subscribers 67
  • Views 18431
How to define a current measurement in ADEXL + Montecarlo using AMS Designer
markris
markris over 4 years ago
Hi All,
I am facing the following issue:
  1. I am currently setting up some montecarlo simulations using AMS Designer in ADEXL.
  2. I need to define a current measurement to be performed during the Montecarlo runs (at 700 us), that I set up in the following way: value(i("/R15/MINUS") 0.0007)
  3. However, for whatever a reason, the measurement fail for each montecarlo run; following you see the error I get at each montecarlo run (this is an extract of the Job.log):
\o ERROR (ADE-2709): Evaluation of output 'test1' returned 'nil' for point:'1' test:'wk_test:test:1'
\o           Expression:'value(i("/R15/MINUS") 0.0007)'.
\o Ensure that the definition of output is correct.
Could it be that my syntax is wrong? If yes, could you please suggest me the correct one?
Thanks in advance!
    Andrew Beckett over 4 years ago in reply to markris
    Looking at the CCR I mentioned above, it appears that it ought to be possible to provide a patch for this that you could load in your environment to fix the issue. However, to get such a patch you would need to file a case with customer support and request a patch for the IC sub-version you're using (please also mention CCR 2213678). I can't create and supply such a patch here in a public forum, unfortunately.
  • markris
    markris over 4 years ago in reply to Andrew Beckett
    Ok, if possible, then I will create a case for it. Thanks again! But I will try first a new version to see if this really solve the issue.
  • markris
    Just as info sharing, I just tried on the fly the IC6.1.8-64b.500.18 version and all is working fine there in ADEXL and Maestro.
    Thanks a lot again.
