  2. Mixed-Signal Design
  3. ocean script if statement not workiing
  • Replies 11
  • Subscribers 68
  • Views 15810
NewScreenName
NewScreenName over 3 years ago
Hi all,
I am new in the use of ocean script, but I would like to perform the following task: use ADE assembler calculator cross() function on a signal, but when a certain design variable A has value 0, then the cross() function should return 0 (rather than nil, 0*nil would still evaluate to nil, so I cannot just multiply them).
I thought to approach this by an IF statement, I tried to look at an ocean documentation, so I created a file called myFile.ocn, loaded it in the outputs setup and its content is:
if (VAR("A")==0 0 cross(vtime('tran "/mySignal") (0.5 * VAR("vsupply")) 1 "rising" nil nil nil))
But that returns eval err. In the ocean reference it is stated that:
"if if( g_condition g_thenExpression [g_elseExpression] ) => g_result Description Evaluates g_condition, typically a relational expression, and runs g_thenExpression if the condition is true (that is, its value is non-nil); otherwise, runs g_elseExpression. The value returned by if is the value of the corresponding expression evaluated.
What am I doing wrong? ADE shows an eval err (it is the case even when I replace the cross() function from the IF with just a number)
Thank you very much
Best regards
    ShawnLogan over 3 years ago in reply to NewScreenName +1
    Dear NewScreenName, No problem with the added questions - we are all beginners at something! NewScreenName said: Still I get an eval err. Is there maybe some other piece of code I should add in the…
    Dear NewScreenName, NewScreenName said: and tried to replicate my setup accordingly, in particular as you can see: Good work so far! You are making progress, albeit I am sure it is frustrating to you…
    Dear NewScreenName,
    NewScreenName said:
    here was indeed a syntax error in how I formulated the nested second if which should have prevented returning nil in my simulation, but did not.
    I am glad you found that! Unfortunately, ocean is not very forgiving of even small syntax errors - which makes it a challenge to debug. I guess I do not have to tell you that now.
    Good luck!
