  2. Mixed-Signal Design
  3. saving bus of nets within an extracted view
  • Replies 15
  • Subscribers 68
  • Views 17067
NewScreenName
NewScreenName over 3 years ago
Dear all,
I am simulating an extracted view, and want to plot some internal nodes. I have followed the instructions at https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od000000050whEAA&pageName=ArticleContent and it works fine for all nets, except those which are defined in the schematic as a bus (e.g. samplenet<99:0> ) and saved in the outputs as /someHierarchyLevels/samplenet<99:0> (in this case only /someHierarchyLevels/samplenet<99> would be saved), while it would work when saved singularly /someHierarchyLevels/samplenet<99>, /someHierarchyLevels/samplenet<98>, /someHierarchyLevels/samplenet<97> and so on.
When a high number of such nets are involved it is quite unpractical to save them singularly, how can I still get them saved without having to expand the whole bus in the outputs tab of ADE assembler?
extraction with Quantus PVS
version:
Thanks and best regards
    ShawnLogan over 3 years ago +1
    Dear NewScreenName, NewScreenName said: When a high number of such nets are involved it is quite unpractical to save them singularly, how can I still get them saved without having to expand the whole…
    ShawnLogan over 3 years ago in reply to ShawnLogan +1
    Dear NewScreenName, I accidentally used the wrong line continuation character. The corrected script and corrected example follow. community.cadence.com/.../screen_5F00_capture.txt Shawn community…
    Andrew Beckett over 3 years ago in reply to ShawnLogan +1
    Shawn, There's a lot of downside in using a pre-run script, and I also don't think it will actually do what you're suggesting. The pre-run script will run before the main simulation (typically used to…
    Shawn,
    There's a lot of downside in using a pre-run script, and I also don't think it will actually do what you're suggesting. The pre-run script will run before the main simulation (typically used to perform calibration etc) but any save settings you make there will not affect the main simulation. Also, it would need to run an additional simulation. Also if running Monte Carlo it would prevent the grouping of points that normally occurs.
     NewScreenName,
    NewScreenName said:
    Thank you Andrew. Now I am wondering, rather than having to include manually this same save.scs file in all the corners I am running (they are quite a lot, and the way I know of to include this save.scs is in the model group of the corner I am simulating) is there a way to include it for all the corners in one place?
    Rather than specifying it as a model file, instead specify it as a definition file on the Setup→Simulation Files form. Then it will be included all the time and does not need to be specified per corner.
    ShawnLogan over 3 years ago in reply to Andrew Beckett
    Dear Andrew,
    Thank you for reading my suggestion and your comment. Not having access to the tools prevents me from verifying my suggestion - so your insight is appreciated as the last thing I want to to do is waste NewScreenName's valuable time! or lead anyone else astray!
    Shawn
  • NewScreenName
    NewScreenName over 3 years ago in reply to Andrew Beckett
    Thank you Andrew and Shawn for your help.
    Regarding this:
    would there be any other way to save nets via an ocean script then? This could be useful for example to enable saving only portions of the circuit depending on some design variable values or similar.
    I guess if the save function is provided it must be possible
    ShawnLogan over 3 years ago in reply to NewScreenName
    Dear NewScreenName,
    Well, since I struck out the first time, I thought a little more and let me try to take a second swing....see what you think!!
    Suppose you setup Assembler to run your basic simulation and include the saved nets for one particular set of design variables. I am assuming you want to choose the output nets to save based on one or more design variables. This setup represents the design variables for one set of saved outputs.
    Now, from the Assembler GUI, save the resulting ocean script (File->Save Script) to a file of your choice. Make a copy of the script (just to have an original copy should you want to refer to it later). Open your favorite text edit and load the copied ocean script. You may now include ocean or SKILL conditional expressions within it to set your saved nets based on the values of one or more design variables.
    After you have made your desired changes, you can run the ocean script from the CIW, UNIX command line or within Assembler itself. When the simulations complete the results can be viewed from Assembler.
    The instructions for creating and running an ocean script are in the Virtuoso ADE Assembler User Guide ICADVM20.1 at URL:
    https://support.cadence.com/apex/techpubDocViewerPage?xmlName=assembler.xml&title=Virtuoso%20ADE%20Assembler%20User%20Guide%20--%20Running%20Simulations%20-%20Creating%20an%20OCEAN%20Script&hash=pgfId-1025280&c_version=ICADVM20.1&path=assembler/assemblerICADVM20.1/asmSimulating.html#pgfId-1025280
    So, not exactly what you might be hoping for as you are using a custom ocean script to run your simulations in lieu of solely the Assembler GUI, but perhaps might spur an idea or two.
    I hope I did not get my second strike!
    Shawn
  • NewScreenName
    NewScreenName over 3 years ago in reply to ShawnLogan
    Dear ShawnLogan,
    Thank you for following up and will give this a try
