  2. Mixed-Signal Design
  3. spectrumMeasurement for a DC signal
  • Replies 18
  • Subscribers 70
  • Views 19534
NewScreenName
NewScreenName over 3 years ago
I have a signal which is DC and some switching activity which disturbs it, therefore I would like to get its THD. The numbers I get using the thd function from the calculator are not right, and according to my understanding this is due to the fact that it will assume the signal is the highest amplitude of the spectrum, and also ignore the DC.
This means that because my signal is the DC, it will actually consider the highest harmonic to be the signal, and the power at its multiples the harmonics.
I tried to solve by calculating with spectrumMeasurement measure types totalharmpower/dcpower, but again I think totalharmpower is still only considering the power of the harmonics of what it assumes to be the signal.
Could not find a function which calculates the power in all frequencies, is there a quick way to automate this measurement? Maybe I am missing the correct calculator function?
Thank you
Best regards
    ShawnLogan over 3 years ago in reply to NewScreenName +2
    Dear NewScreenName, In viewing your results and realizing you are using the Spectrum Assistant, I feel as if I should add a few more comments regarding its use in your specific application. My understanding…
    Dear NewScreenName, I was very happy to read you were able to understand my comments! NewScreenName said: I just have a question about your method: according to what I see the FFT is displaying the…
    ShawnLogan over 3 years ago +1
    Dear NewScreenName, NewScreenName said: Could not find a function which calculates the power in all frequencies, is there a quick way to automate this measurement? Maybe I am missing the correct calculator…
  • brs2020
    brs2020 over 3 years ago in reply to ShawnLogan
    ShawnLogan - I went through the document above where you explain that the dft gives the amplitude instead of the rms. The explanation was the dft multiplies the bins by sqrt(2). I think this is true for non-zero bins. For the zeroth bin, there is no multiplication by sqrt(2) if I understand it correctly. i.e. to find the DC power we would need X[0]^2, for other bins we need X[n]^2/2 for n=1,2,... Can you confirm
    ShawnLogan over 3 years ago in reply to brs2020
    Dear brs2020,
    That is correct. The DC amplitude is not subject to any multiplication. This is actually a general result when determining the single-sideband spectrum for a DFT (or FFT) from its conventional two sided spectrum. For real signals, the amplitudes of the corresponding positive and negative frequency are complex conjugates. Hence, the equivalent power for the single-sideband spectrum may be found by multiplying the positive frequency powers by 2. Since the DC term is neither positive nor negative, it is not multiplied by 2.
    I hope my explanation makes sense brs2020!
    Shawn
  • brs2020
    Dear Shawn,
    Thanks for your reply. I think you mean single-sided spectrum when you say single-sideband spectrum. Your reply makes sense, for real signal the power of the single-sided spectrum is obtained by taking the power of the positive frequencies of the double sided spectrum and multiplying by 2.
    The cadence dft function behaves somewhat unconventionally in my opinion. For example, if you have a signal x(t) = Ao + Ao*sin(2*pi*fo*t), i.e. a signal with a DC term. A single-sided spectrum using FFT function on Matlab (or also likely Octave) would result in 6dB difference between the DC term and the term at fo. This makes sense the DC power = Ao^2 and the power at fo=Ao^2/2. However, if we were to plot the FFT using the Cadence dft function, the DC term would be at the same level as the term at fo. This indicates that the cadence dft function, when getting the single-sided spectrum internally multiples the positive frequency bins by 4 instead of 2, but leaves the DC term as is.
    Put differently, referring to the screenshot below from your document, I wonder if the sum of squares of the dft() function produces a value slightly different from twice the expected value, since the X(0) term is not treated the same way as other |X(n)| n=1,2,.... i.e. when you consider a signal of the form x(t) described above, the sum of the dft terms divided by 2 will likely not match the ideal value you would expect theoretically. Do you agree?
    Dear brs2020,
    Thank you for correcting me - yes I intended to write single-sided spectrum and typed single-sideband spectrum. Sorry for that confusing error on my part!
    I agree and reported this discrepancy to Cadence in an SR. Both the Octave and Matlab implementations of the FFT make use of the FFTW algorithm. FFTW is a well known and proven algorithm originally developed at MIT with source code in C and FORTRAN available on-line. Details of the algorithm and benchmarks are described by the original authors in a 2005 paper at www.fftw.org/fftw-paper-ieee.pdf which is also available from their site www. fftw.org.
    My only thought as to why Cadence chose to deviate from this algorithm is that it wanted the magnitude of its tonal spectral peaks to correspond to the amplitude and not the rms value of the tones. However, I have no further insight as I never received a Cadence response to the SR nor the supporting documentation I provided to them. I believe their choice is confusing when attempting to use their DFT result in an integration to compute signal power (i.e., make use of Parseval's theorem).
    In short, I also agree, but do not have any available dft() results for a signal with a significant DC term to validate the hypothesis. As I note in a response to the original forum question:
    "Yes. In fact, on the second page where I compute the total power exclusive of DC , you might note I did not use the 1 V amplitude of the reference level of the Spectral Assistant (0) to compute the 5 MHz signal power. I used a value of 0.707 V - which is the rms value (see below) of its 1 V amplitude in order that the total power exclusive of DC be an rms value."
    A good discussion and thank you for asking the question!
    Shawn
    Dear bus2020,
    I wrote a response, but it was flagged as spam as I included non-Cadence links (albeit I made an attempt to disguise them). Hopefully, it will be released in order that you may review it.
    Shawn
  • brs2020
    Thanks Shawn, appreciate your comments.
    Andrew Beckett over 3 years ago in reply to brs2020
    I don't have the time at the moment to dive through all the details of this conversation other than to note that the dft function is actually using FFTW under the hood (a change was made a number of years ago to move from an internally-developed FFT function to use FFTW instead - this then allowed non-power of 2 numbers of samples). Of course that doesn't mean that there isn't some difference in scaling - I can't comment on that without spending more time.
    I didn't find any case from you Shawn on this - so hard to know what the outcome was.
    ShawnLogan over 3 years ago in reply to Andrew Beckett
    Dear Andrew,
    First, thank you for even taking the time to weed through our discussion - I am not sure how you manage to find the time!
    I did not realize the algorithm was updated to use FFTW - thank you for filling me in!
    I actually provided the note and my comments as a feedback entry to the relevant Transient Noise Application note as my open cases were all closed when I left my former employer.
    I should have been more clear - sorry!
    Shawn
