  3. Shape with Rounded Corners
  • Subscribers 163
  • Views 21630
Khurana
Khurana over 17 years ago
Is there a way to create a shape with rounded corners in a single step?  I know the 1) create shape then 2) Edit Boundary method that requires users to define arc begin/end points but this is for create a shape symbol (ssm) and can be quite tedious especially when you do this all day long (as a librarian).  Are there short-cuts to this?
Using Allegro PCB Editor XL v16.2 with hotfix..
  • mcatramb91
    mcatramb91 over 17 years ago
    I would create a Dynamic shape then change the shape type to Static inside of a design file (.brd) and use sub-drawing to cut and paste your static shape into your shape symbol.   Dynamic shapes automatically add fillets to the sharp corners of the shape and changing the shape type to Static preserves the fillets as arcs.
    Inside of the Symbol Editor (Shape, Package, Mechanical, etc) you do not have the ability to add a Dynamic shape with the automatically fillets so you will need to do it in a design file (.brd) and simply cut and paste it into a symbol .dra.
    Hope this helps,
    Mike Catrambone
  • aCraig
    aCraig over 17 years ago
    Khurana,
    Go to Setup->User Preferences->Shapes->Voiding and change av_endcapstyle and dv_endcapstyle to round.
    NEVER MIND my bad I thought this work with shape creation as well. Sorry for any confusion.
    -Craig
  • jch teyssier
    jch teyssier over 17 years ago
     Other way:
     Create your shape, decompose it to obtain lines, use filletting (dimension menu), compose the shape with the new lines.
    Or draw lines directly with arcs or linesand filletting, and compose shape.
  • Khurana
    Thank All.
    Mike's method is the only thing that's closest since decompose shape & add line are grayed out in shape symbol mode.  Was hoping that Fillet command would work but not only is it not there in shape symbol mode but it also does not work on a shape (i.e. works on lines only)...probably that's why it's not there.
    Another CCR...
