  2. Allegro X Capture CIS
  3. Dumb Question about Orcad on Linux
  • Replies 10
  • Subscribers 52
  • Views 28699
RayDude
RayDude over 16 years ago
I've been using Orcad on PC for about a year now. I'm a unix lover and have gotten the Sys Admin to install Cadence 6.3 on our linux box and setup the license server.
However, I can't figure out what the executable for Orcad is called. There's no capture or orcad executable.
So how do I run it? Is there something special to install it?
Brian
  • AvengerThanos
    AvengerThanos over 5 years ago in reply to oldmouldy +2
    Just refreshing the question once again since the post is a decade old. With all new developments and updates can 17.4 OrCAD professional with PSpice work on Linux? or any other OS apart from Windows…
  • redwire
    0 redwire over 16 years ago
     Since when does it (OrCAD) run under Linux?  I am only aware of it running under windows. http://www.cadence.com/rl/Resources/datasheets/7440_Schematic_Capture_DS_FNL.pdf
    Maybe 16.3 is supposed to?
  • oldmouldy
    0 oldmouldy over 16 years ago
    Nope! OrCAD Capture is a "Windows only" tool compiled to run with Windows libraries, and that applies to any and all versions of OrCAD Capture. The SPB16.3 install for Linux will install the "UNIX" tools, that's Design Entry HDL for the front end, PCB Editor for physical backend, PCB Router for autorouting and PCB SI for signal integrity analysis. You could get PCB Editor to start from an OrCAD PCB Editor license but I doubt that the OrCAD PCB Editor level licensed product was tested on Linux.
  • RayDude
    0 RayDude over 16 years ago
    Thanks. Time to fire up Wine.
    Brian
  • redwire
     Keep us posted on your results. I"d like to know how the license manager crosses over between WINE and LINUX.  I guess you have to an install on the "windows" side as well?
  • RayDude
    Its been done, see link below. I don't know when I'll get to it, I'm debugging my board now.
    http://appdb.winehq.org/objectManager.php?sClass=version&iId=6099&iTestingId=13165
