  3. asign a net name to a dummy net
  • Replies 10
  • Subscribers 166
  • Views 26100
Kennn
Kennn over 16 years ago
I am a new user of Allegro PCB editor of OrCAD 16.2. I want to modify an existed PCB design (*.brd). I add a set of new connect pins and want to assign nets to that pins (dummy nets). Question is I do not know how to do it.
I read someone's suggestion is utilizing "Net Logic" on Logic menu. But I not found "Net Logic" on Logic menu. There are only "Identify DC Nets", "Assign EefDes", and "Auto Refdes".
I was stopped there, please giving me a clear method to solve it. Thank you!!
  • Afgncaap
    Afgncaap over 15 years ago
    OK, my response may be a bit late in this, but I figured out how to do at least some of what you want to do: If you want to assign a net to a SHAPE, this can be done but it is not intuitive. I first discovered that under the Shape menu, there is an option called "Edit Boundary." When you select a shape with this command and right click, there is the option to "Assign Net." THIS DOES NOT WORK. It will claim to work, and then still fail. Instead, deselect your shape and go to the Shape menu. Choose "Select Shape or Void" and then select your shape. If you do this, all of the vertices in the shape should get little boxes (so this is really handy if you want to change the shape, too). Go to the Options tab on the right side and choose the desired net from the drop down menu. Now right click on the shape and the "Assign Net" option will work. Hope this helps you. This was the only way I could find to get an odd shaped ground plane and have the power plane underneath it be shaped the same (without redrawing the whole thing).
  • Afgncaap
