  3. subdesign suffix separator problem
  • Views 14433
Samuel Zhang
Samuel Zhang over 14 years ago
Hi all, I encounter a question about the subdesign suffix separator. When I setup the separator as "/",the result is what I expected in Allegro, the reference desiganators of reuse blocks are all with "/", like "U14/5". but when I set back the separator as "_", and then packaging the schematic, the "/" of ref des can't change back to "_", the expected result is something like "U14_5".
Could anyone  explain what the problem is? Is this operation one-off and irreversible? Thanks in advance.
  • Mike Veal
    Mike Veal over 14 years ago
     Have you made sure that the Package Option radio button is set to 'Repackage' and not 'Preserve'?
  • Samuel Zhang
     Thank you Mike, I already fixed the problem.The Ref Des Pattern is not configured correctly.
