  3. Orcad Vs. Allegro
  • Subscribers 163
  • Views 35455
Orcad Vs. Allegro
purikku22
purikku22 over 14 years ago
what is the difference between the Orcad 16.5 to Allegro PerformanceOption - L V16.5?
are the designs convertible from Orcad to Allegro and vice versa? Since both are cadence softwares.
Thank you!
  • steve
    steve over 14 years ago
    Yes the are effectively the same. Same database, libraries etc. You can open Allegro files in OrCAD and vice versa. OrCAD PCB Editor is a cut down version of Allegro PCB Designer. Since 16.5 there is no longer L, Performance, XL. The Allegro PCB Designer is effectively Allegro L + Performance plus other bits from XL. There are add on's called Miniturization, High Speed, RF.
    OrCAD PCB Editor has two types, Professional and Standard. Standard has no auto-router, no electrcial constraints, Professional has auto-router, diff pairs, total etch length, constraint regions. Here's a comparsion chart
    http://www.parallel-systems.co.uk/e-mail/PCB_Suites-MATRIX.pdf
  • purikku22
    thanks steve for the link. i will study the difference. we are planning to add some licenses using orcad if its compatible with the allegro platform with the cutdown price. is it possible to convert .pcb (zuken) files to orcad and vice versa without using 3rd party softwares? thank you, have a nice day ^^
  • Ejlersen
    Ejlersen over 14 years ago
    Hi
    Unfortunately there is no way to convert Zuken files without third party software.
    Best regards
    Ole
  • purikku22
     Thanks Ole for the reply.
    I search google and found some Old forums, that its possible to translate Cadstar to Orcad? Is that still possible with the Latest version of ORCAD? Thanks
    regards,
    Eric
  • steve
    No. You used to be able to translate Cadstar (CDI) to OrCAD Layout (max) which was the old PCB tool. It's not avaliable now unles you have an install of 16.2 or older. The process would be Cadstar CDI to MAX then MAX to Allegro BRD.
