  3. Layer to Layer Registration
  • Views 16646
Ron Scott
Ron Scott over 13 years ago
I need to clarify my fab notes and I need to know specifically which IPC document talks about layer to layer registration. I've been through the 6011 & 6012
Thanks.
  • budnoel
    budnoel over 13 years ago
    I don't know if this is what you're looking for but IPC-2222 Section 9.1.5 states the following: The presentation in Table 9-3 is for the tolerance to be applied to the nominal dimension chosen for the location of the lands connector contacts and conductors in relation to the datums.  This tolerance includes tolerances for master pattern accuracy, material movement, layer registration and fixturing. I've attached a jpeg of Table 9-3 to this post.
  • Ron Scott
    Thanks but that was not what I was looking. I did finally find the source I needed which is: IPC-6012 Rev C (Book) Paragraph: 3.4.2 Table: 3.8 Had our documentation team order book right away. Ron Scott
