  3. Copper Pours
  • Views 15503
Copper Pours
Brian Rocks
Brian Rocks over 10 years ago
I am still a noob when it comes to the PCB portion of Orcad.  I have a 4 layer board and am ready to make the pours for the ground/power planes.  How is this done properly?  I have done:
  1. set a "keep in" rectangle inset in from the board outline.
  2. Add: Frectangle on the ground layer
  3. Select the "0" net
However, when I do this, all of my through holes give me a DRC error: Thru Pin to Shape Spacing
I also get an error for the keep in layer: Shape to Route Keepin Spacing
  • steve
    steve over 10 years ago
    A better way is to use Edit - ZCopy, look at the Options menu and set class/subclass to the layer you want the pour on, make sure you check Create Dynamic shape, set a value of contract (to offset from the board outline) then left click the board outline. The copper pour is contracted from the outline. This is easier if your outline is a complex shape. Now assign a net name to it (Shape - Select shape or void then left click the shape and set the net name from the Options menu. The Frectangle command always adds a Static shape which will not void automatically.
  • steve
