  3. Problem with rotating component using iangle
  • Subscribers 162
  • Views 19837
michielqpi
michielqpi over 9 years ago
At the moment I'm using Allegro 17.2. For rotating components I use the iangle function: funckey r iangle 90
Normally it rotates the component perfectly in placementedit mode, but for some designs it doesn't rotate and I get a weird response: Element is already set to this angle.
How can I fix this problem?
Normally it rotates the component perfectly in placementedit mode, but for some desings it doesnt rotate and I get a weird respons: Element is already set to this angle.
Can it be that I accidently selected something wrong in the options?
- See more at: community.cadence.com/.../36093
Problem with rotating component using ianglea
- See more at: community.cadence.com/.../1347623
  • oldmouldy
    oldmouldy over 9 years ago
    From the main menu, take Edit>Rotate, check the Options tab, likely the Rotation Type is not Incremental, probably Absolute, change this to Incremental, go to the canvas and perform a "dummy" rotate to confirm the settings and then Done. The next "Rotate" will use the Incremental setting.
  • michielqpi
    Thank you oldmouldy! It was already on incremental at edit>rotate, but it wasn't in placementedit when I selected the component. I had to RMB --> options --> incremental
  • markwood
    markwood over 4 years ago
    [deleted]
  • shannusamosa
    shannusamosa over 4 years ago in reply to markwood
    [deleted]
    • Vote Up -1 Vote Down
  • Wild
    Wild over 4 years ago in reply to shannusamosa
    So much spam lately.
