  2. Allegro X Capture CIS
  3. Annotation Fails for a heterogeneous part in a special ...
  • Subscribers 52
  • Views 25809
Annotation Fails for a heterogeneous part in a special sheet
Hossein1357
Hossein1357 over 10 years ago
I have created a heterogeneous part and I am using two of them in some of sheets in a design. Although I have used a uniqe part in two sheet, one of them fails in Annotation. I see below error message:
ERROR(ORCAP-1376): Cannot perform annotation of heterogeneous part 'U?C(Value AD9914) at location (2.80, 1.00) on page 07- DDS2 Power & CAPs', part has not been uniquely grouped (using a common User Property with differing Values) or the device designation has not been chosen
Hossein
  • steve
    steve over 10 years ago +1
    You need to add a group property to each part so that Capture knows which parts are grouped together. Look at:- orcad.co.uk/.../Annotating_Multi_section_parts.pdf
  • steve
    0 steve over 10 years ago
  • Hossein1357
    0 Hossein1357 over 10 years ago
    Thank you so much. I had not used two or more Heterogeneous parts in a design and that's why I couldn't realize the problem. I just managed to solve the issue by the second option. I mean I ran tcl\tk application Dashboard and set that property.
  • ichliebedich
    0 ichliebedich over 5 years ago in reply to Hossein1357
    where did you request the "capCBWareAddHeteroProp.tcl" file? I can't find where can I request it on Parellel Systems site.
  • steve
    0 steve over 5 years ago in reply to ichliebedich
    Here it is. Put this in your %HOME%\cdssetup\OrCAD_Capture\tclscripts\capAutoLoad folder then restart the tools.https://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/27/5482.capCBWareAddHeteroProp.zip
  • ichliebedich
    0 ichliebedich over 5 years ago in reply to steve
    thank you steve!
