  3. Maintain "Persistence" of Find after done command is completed...
  • Replies 23
  • Views 10157
Maintain "Persistence" of Find after done command is completed while routing.
excellon1
excellon1 over 7 years ago
Hi.
When in EtchEdit mode or general edit mode for routing I notice that when routing is finished by selecting "Done" the settings in the find dialog
settings get blown out.
I am trying to maintain the relationship between adding etch with find after the fact. In other words after etch is added to the canvas I want the
find dialog to retain ( Cline Segs, Pins, Nets, Rats T etc ) so that those items are selectable for either info or basic editing after the fact.
Is there any way to accomplish this other than creating a macro for find entities ?.
Basic idea is to have find pre-checked for a given command such as routing etc.
Something like a "IF Done" at the macro level would be helpful too though I do not know if something like that is supported ? , Like execute
the macro, after done is selected as an action then the macro runs the part to check find dialog items.
Thanks Paul.
  • lcan
    lcan over 7 years ago
    Paul,
    I’m coming to this topic late… apologies. I had similar Find Filter concerns, along with others that I wanted to address. This might be more than what you want, but it builds off of Rik's input which I think he gave me a while back and I have found very helpful.
    -      Like you, I wanted the Find Filter defined with baseline settings dependent on the Application mode, and
    • to re-use the same keyboard keys for dissimilar functions across Application modes. (Impossible with a straight ENV file solution)
    • to define non Application mode Alias and Function keys depending on the Application Mode I invoked.
    • to quickly modify the Find Filter without having to see it, or mouse to the Find Filter.
    • to quickly switch to other Application modes
    • for Etch Edit mode baseline grid auto set to 2.5 mils, for Placement mode baseline grid auto set to 25 mils.
    I invoke this by putting the command name in the Allegro.men file.
    Bill
    axlCmdRegister("wtm_EtchKeyPad"  `wtm_ee_MKeyPad)
    procedure( wtm_ee_MKeyPad( )
               axlSetFunckey( "/" "prepopup; pop dyn_option_select 'Selection set@:@Select by Lasso'" t)
               axlSetFunckey( "*" "prepopup;pop neck" t)
               axlSetFunckey( "-" "prepopup;pop finish" t)
               axlSetFunckey( "Home" "prepopup; pop dyn_option_select '@:@Auto-interactive Delay Tune'" t)
               axlSetFunckey( "Up" "prepopup; pop dyn_option_select '@:@Delay tune'" t)
               axlSetFunckey( "SUp" "prepopup; pop dyn_option_select '@:@Add vertex'" t)
               axlSetFunckey( "Pgup" "prepopup; pop dyn_option_select '@:@Add connect'" t)
               axlSetFunckey( "Right" "prepopup; pop dyn_option_select '@:@Scribble mode'" t)
               axlSetFunckey( "Down" "prepopup; pop singletrace" t)
               axlSetFunckey( "Pgdown" "prepopup; pop dyn_option_select @:@Move;" t)
               axlSetFunckey( "SPgdown" "prepopup; pop dyn_option_select '@:@Move vertex';" t)
               axlSetFunckey( "Insert" "prepopup; pop dyn_option_select @:@Delete" t)
               axlSetFunckey( "CInsert" "delete by rectangle " t)
               axlSetFunckey( "SInsert" "delete by line " t)
               axlSetFunckey( "End" "prepopup; pop dyn_option_select @:@Slide; setwindow form.mini; FORM mini extend_selection NO; setwindow pcb" t)
               axlSetFunckey( "CEnd" "prepopup; pop dyn_option_select @:@Slide; setwindow form.mini; FORM mini extend_selection YES; setwindow pcb" t)
               ; Non Application Mode Keys
               axlSetAlias( "F9" "phase_tune")
               axlSetFunckey( "F10" "tvision; setwindow form.find; FORM find Nets YES; setwindow pcb" t)
               ; Find Filter - Interactive Modification
               axlSetAlias( "f1" "replay C:/Cadence/SPB_17.2/share/local/pcb/scripts/ff_clines_only.scr")
               axlSetAlias( "f2" "replay C:/Cadence/SPB_17.2/share/local/pcb/scripts/ff_csegs_only.scr")
               axlSetFunckey( "Left" "settoggle CMD f1 f2; $CMD;" t)
              ; Keyboard Switch - Application Modes
               axlSetAlias( "t1" "wtm_EtchKeyPad")
               axlSetAlias( "t2" "wtm_PlaceKeyPad")
               axlSetFunckey( "F12" "settoggle CMD t1 t2; $CMD" t)
               ; Set a grid for working in Etch edit mode.
               grid = axlDBGridGet("TOP")
               grid->name = 'all
               grid->xGrids = 2.500
               grid->yGrids = 2.500
               axlDBGridSet(grid)
               axlShell( "etchedit" )
               ; Find Filter - Baseline Settings
         axlShellPost( "setwindow form.find; FORM find all_off; FORM find ratsnests YES; FORM find Pins YES; FORM find Vias YES; FORM find cline_segs YES; setwindow pcb" )
    ); procedure
  • excellon1
    excellon1 over 7 years ago in reply to lcan
    Bill in looking at your file, it strikes me that it is kind of like a Skill command that gets loaded, would that be right ?. I like the concept of what you have seems good and a time saver.
    Thanks Paul.
  • lcan
    lcan over 7 years ago in reply to excellon1
    Hi Paul,
    Exactly.  I was hoping to keep the SKILL commands simple for easy editing by myself and others. PCB Design is my more core competency, not SKILL coding.
    Here is what I use for "Placement mode":
    axlCmdRegister("wtm_PlaceKeyPad" `wtm_pe_MKeyPad)
    procedure( wtm_pe_MKeyPad( )
    axlSetFunckey( "*" "replay C:/Cadence/SPB_17.2/share/local/pcb/scripts/toggle_rot_sym_orig_increment.scr" t)
    axlSetFunckey( "-" "replay C:/Cadence/SPB_17.2/share/local/pcb/scripts/toggle_abs_sym.scr" t)
    axlSetFunckey( "Home" "prepopup; pop dyn_option_select '@:@Swap components'" t)
    axlSetFunckey( "Up" "iangle 90" t)
    axlSetFunckey( "CUp" "move; ipick_to_gridunit 0 +1" t)
    axlSetFunckey( "Pgup" "prepopup; pop dyn_option_select @:@Rotate" t)
    axlSetFunckey( "Right" "prepopup; pop dyn_option_select '@:@Swap pins'" t)
    axlSetFunckey( "Down" "prepopup; pop mirror" t)
    axlSetFunckey( "SDown" "prepopup; pop dyn_option_select @:@Mirror" t)
    axlSetFunckey( "CDown" "move; ipick_to_gridunit 0 -1" t)
    axlSetFunckey( "Pgdown" "prepopup; pop dyn_option_select @:@Move" t)
    axlSetFunckey( "End" "prepopup; pop dyn_option_select '@:@Show Rats'" t)
    axlSetAlias( "f1" "replay C:/Cadence/SPB_17.2/share/local/pcb/scripts/ff_pins_only.scr")
    axlSetAlias( "f2" "replay C:/Cadence/SPB_17.2/share/local/pcb/scripts/ff_text_only.scr")
    axlSetAlias( "f3" "replay C:/Cadence/SPB_17.2/share/local/pcb/scripts/ff_sym_only.scr")
    axlSetFunckey( "Left" "settoggle CMD f1 f2 f3; $CMD" t)
    ; Set a .5MM grid for working in Placement edit mode.
    grid->name = 'all
    grid->xGrids = 25.000
    grid->yGrids = 25.000
    axlDBGridSet(grid)
    axlShell( "placementedit" )
    axlShellPost( "setwindow form.find; FORM find all_off; FORM find Symbols YES; setwindow pcb; move; setwindow form.mini; FORM mini stretch YES; setwindow pcb; prepopup; pop dyn_option_select 'Options@:@Rotation point@:@Symbol Origin'; prepopup; pop dyn_option_select 'Options@:@Rotation type@:@Incremental'; done")
    ); procedure
    Again, to invoke these I create a new popup on the Main Pulldown menu by putting this in the C:Cadence\SPB_17.2\share\local\pcb\menus\Allegro.men file...
    POPUP "&Application Mode"
    BEGIN
    MENUITEM "Placement Edit", "wtm_PlaceKeyPad"
    MENUITEM "Etch Edit", "wtm_EtchKeyPad"
    END
    Hope you find it useful.  You will notice I use the mini keypad on the right of the keyboard, that's just my historical preference.  Modification to use the main keyboard keys should be a straightforward process.
    Bill
  • steve
    steve over 7 years ago in reply to lcan
    Lots of you are editing the menu file which isn't really recommended anymore - if the menu file changes you won't see the updates. You'd be better off using the skill file to load your menu. Details can be found here:- http://orcad.co.uk/images/PDF/PCB_Editor_customization.pdf Page 2 gives you a sample skill file that builds a user-defined menu, you then use an allegro.ilinit file to auto load this menu when you start the tools.
  • lcan
    lcan over 7 years ago in reply to steve
    You are absolutely correct, Steve.  My method of using a manually edited Allegro menu file then placed in the local folder is somewhat stale, while functional.  Perhaps that was why I mentioned SKILL coding was not my core competency. I hope folks find the main functions useful. I will research your suggestion, thanks!
    Bill
  • lcan
    Bill
  • riklee
    riklee over 7 years ago in reply to lcan
    I'd like to add that you should not be storing your scripts (or views, extract files etc) in the Cadence hierarchy. There is a scriptpath variable  that you can set to point to your scripts in a local directory e.g. %home%/pcbenv/scripts
    If you had to reinstall the release you could end up losing all the work you put into making the scripts and any other files that you use.
  • lcan
    lcan over 7 years ago in reply to riklee
    Rik, thanks for the ancillary data management tip although I would disagree when the customer installation is multi-user server. Backups are mandatory, regardless of installation type.
    What I hope does not get lost is the original topic, the need for a smoother interface in the PCB Editor. Although much wonderful work has been done to Allegro in the past 12 years, there is still a strong need to overhaul its user interface to capitalize on all the robust functionality the Application Modes offer. It is this area where our users want Cadence support and Engineering to focus. With all this excellent new functionality and analysis, putting it at the PCB Designers/Engineers fingertips is essential. Lets focus a little more on what people are asking for that makes the tool easier to use, like Paul did.
  • riklee
    I'd be an advocate for using cds_site if it's a multi-user environment for those that would use the same scripts or other files. You can use cds_site as well as a 'personalized' environment without storing files in the Cadence hierarchy
  • lcan
    When I have more UI enhancements from our users, I'll be sure to send them along to you.
  • excellon1
    Some awesome feedback guys, really do appreciate the help. In looking over the UI my leaning is to Bill's view. The key is to have a productive UI to drive the tool. Allegro has some truly great features but the crux is the learning curve. Kind of makes things a bit of a hard sell. I personally have been doing PCB design for a long time, used lots of packages over the years. I hail from P-CAD Master Designer so getting up to speed on Allegro was not horrible but there sure is a hell of a lot to learn :), but that's kind of cool IMHO.
    It would be great if some of the common things such as setting grids etc for example were better addressed. Certainly power is available via scripting and skill but your average user may find that difficult. So things can become a struggle pretty fast If you don't get an early grasp of the tool.
    Not to go off topic but perhaps an example to illustrate something that I think was not very well thought out from a UI perspective.
    Take any design and add a couple of global vias to all nets in the design. Fairly easy to do in the CM after a bit of fiddling. Now in the UI have the options pane open and click on the add a connect Icon so as to invoke routing on the layer of your choice using ALT Mode.
    So what's odd about the Options panel. Well you see a message saying "No available Via" But you just added them to all nets so where on earth are they ? and you also clicked add a connect.
    Well the via choices only show up when you click the mouse on the canvas after first clicking "Add a connect". That just seems backwards to me and not intuitive. If you are used to the tool you may never see this because you are either using hot keys to automate things or your a seasoned allegro user and move pretty fast that the message is not noticeable. It is not a big deal really but there is a problem with the physical action of clicking the add a connect icon and association of UI elements to that action.
    Maybe not the best example of UI high strangeness but you get the idea.
    Back to scripts. I was wondering if there is any way to have a Ruler to measure between two points similar to what's in spectra or dare I say it Mentor, yikes sorry..
    I hate with a passion seriously using the "Measure" tool to just do a fast and dirty measurement between two points, for example something like a fast check of pin spacing or a quick check of distance. Believe it or not I am actively using the "Add a line tool" in relative mode to do such measurements. just feels more natural to me. Yep old habits and the way things work in other tools die hard. I can see the power under the hood in how the measure tool works, it provides lots of info.. It just does not feel natural to use. It is far easer IMHO to just draw a line on the canvas, seems less clumsy.
    Steve had a good point above about not editing the mem file, but to Bill's point I agree that some UI over haul would be of benefit.
    The scripts are great, I have done a bunch of automation here and boy oh boy Allegro is so fast. I am in fat city :) having fun too. I found making things like dedicated folders for Scripts, padstacks, libs, parameter files etc independant of the cadence folder is working well and easier to keep track of.
    Thanks Paul
