  3. MAX file
  • Replies 8
  • Subscribers 167
  • Views 25693
MAX file
AutoMike
AutoMike over 7 years ago
I have a MAX file from Samtec, which should be a connector footprint. I've been searching for how to Import it but haven't found anything that makes sense.
Any help would be appreciated, thanks
  • steve
    steve over 7 years ago
    A MAX file is an OrCAD Layout file which depending on which version of PCB Editor you are using can be imported using File - Import - Cad Translators - OrCAD Layout (or Import - CAD Translators - OrCAD Layout). If you have 17.2 you'll need to enable this import from Setup - User Preferences - unsupported and enable layout2allegro_unsupported then restart.
  • AutoMike
    AutoMike over 7 years ago in reply to steve
    Hi Steve,
    I'm using OrCAD PCB Designer Professional 17.2-2016 but I do not see the Options that you say, which was my reason for the post.
    If I'm in the package Editor I see the following window: ( I can't load a file here whatever size I make it, always an error)
    I have File > Import > Artowrk, IPF, DXF, IDF, Sub-Drawing, CSV Pin File, Logo, Techfile, Parameters.
    If I'm in layout mode then there is no File > Import but there is:
    Import > Netlist, MCAD, Color/Board Parameters, Techfile, Clipboard, Placement, Translators, More,
    under Translators > PADS, PCADS, PADS Library, Altium PCB, Altium Schematic
  • steve
    steve over 7 years ago in reply to AutoMike
    So you'll need to enable it from Setup - User Preferences - unsupported - enable layout2allegro_unsupported
  • AutoMike
    enable layout2allegro_unsupported  doesn't appear in my list
  • steve
    Sounds like your not running the latest hotfix. Cannot remember exactly which hotfix this was included in but if you get the latest S032 then it's definitely there.
