  3. Change shape color while editing
  • Replies 7
  • Views 19438
KEN13
KEN13 over 7 years ago
Good afternoon all,
I use PCB Editor version 17.2.  I select a shape to edit.  Move my cursor over one edge to drag larger or smaller.  When I do this the shape edge I am moving changes to black.  How can I change this color as I use a black background and can not see the line as I am moving it.  I can change the background color to a lighter color and see the line as I am moving it, but find a black background is easier on the eyes.
Thank you,
Ken
  • excellon1
    excellon1 over 7 years ago
    Ken, this sounds like that your temporary Highlight color is set to Black in your design. Go to display and choose "Color/Visibility" which willl open the color dialog. In the left pane click on "Display", in the right pane
    you can change the colors for various elements.
    Maybe that's it ?
    Paul.
  • KEN13
    KEN13 over 7 years ago in reply to excellon1
    Excellon1, thank you for the suggestion, unfortunately that is not it.  I have it set to yellow.  When I select the shape it highlights in yellow.  Once I begin to drag the edge it turns to black.
  • excellon1
    excellon1 over 7 years ago in reply to KEN13
    Hi Ken, this seems very bizarre.
    Here is a picture editing a shape in 16.6, you can see that when I drag the handles I get a red line to indicate where the shape is expected to be. The shape is on the top etch layer.
    If you don't see something similar post a picture of what you see at your end.
    Paul.
  • excellon1
    Paul.
  • KEN13
    Paul,
         Thank you for the reply.  I actually have an old CPU with 16.6.  When I select the shape and drag it the line changes to red.  On 17.2 it is black.  So hopefully on the next update it will be fixed.
    Ken
  • excellon1
    Hi Ken, I checked 17.2 ver SO42 that I have running on windows 10, same hardware as what I run 16.5 on and I can see the red handles on the shapes without issue.
    By way of a suggestion, see if any video driver updates are available for your video card.. Updated drivers may fix things for you
    Paul.
  • KEN13
    Paul,
         It must be a setting I am missing.  I needed to update a footprint in my library and when I drag the Place Bound Top shape it does change to red.  Try the same in the board file and it is black.  I saved the color palette for library and loaded it on the board file...no such luck.
  • excellon1
    Ken I assume your on windows right ?. If you were able to edit a symbol and the shape drag operation is red then I believe that your .env file probably does not have some bizarre option checked. Maybe try a DB Check on that pcb database and look at the log to see if you get any hits. If you want to zip up your .env file I can take a look to see if I spot anything obvious. Beyond that a call to support may be needed to resolve your issue.
    Paul.
