  3. How do we prevent black box 3D models for footprints?
  • Replies 18
  • Subscribers 167
  • Views 23119
Mysil B
Mysil B over 6 years ago
Hello
We have some components on our PCB that has no step file associated because they are simply just pads. How do we prevent OrCAD from adding black boxes with the default comp height on the footprint in the 3D viewer?
Regards
Mysil
  • Mysil B
    Mysil B over 6 years ago in reply to Sagetech
    For STEP models that can be done in the export dialog. For IDF try setting the default package height to 0...
  • steve
    steve over 6 years ago in reply to Mysil B
    You can add a property to the PLACE_BOUND shapes called IDF_EXCLUDE which stops the shape being exported to IDF.
  • Sagetech
    Sagetech over 6 years ago in reply to steve
    Ok, I'll give that a try. Thanks!
    Tom
  • Sagetech
    Sagetech over 6 years ago in reply to Sagetech
    Didn't work..........
  • steve
    steve over 6 years ago in reply to Sagetech
    So that is setting a user preference - try Edit - Properties then select the shape or shapes and add the property direct to the PLACE_BOUND shape. You will have to do this on a part by part basis.
