  3. Decoupling capacitors and ground planes
  • Subscribers 166
  • Views 14560
SandeepDaftor
SandeepDaftor over 6 years ago
I'm making my first ever PCB, a very simple programming board for ATMEGA328p chips. I've got decoupling caps either side of the chip between +5V and GND. tutuapp
Question I have is that I'm using a copper pour on the top layer as a ground plane, and as well appvalley as the ground pin on the capacitors being connected to ground, the actual ground pin on the IC itself is also connected to ground.
Is that an issue? Should the only connection to ground come from the capacitor? tweakbox
  • RFinley
    RFinley over 6 years ago
    http://www.sigcon.com/Pubs/news/9_07.htm
    http://www.sigcon.com/Pubs/edn/ParasiticInductance.htm
    https://learnemc.com/emc-tutorials
    https://incompliancemag.com/article/decoupling-capacitor-design-on-pcbs-to-minimize-inductance-and-maximize-emi-performance/
    If you are making a 2-layer board for cost reasons...
    https://www.signalintegrityjournal.com/blogs/12-fundamentals/post/1207-seven-habits-of-successful-2-layer-board-designers
  • CadAce2K
    CadAce2K over 6 years ago
    No. Not necessary. As long as the +5V cap is near the pin, the return gnd loop will be short. Typical.
