• Home
  • Community
  • Forums
  • PCB Design
  • Padstack editor in 17.4 trial version
PCB Design Forums
Joel88
Joel88 8 days ago
I just downloaded the trial version of Orcad 17.4. I'm am watching a tutorial to get started with the soft and I have to use the padstack editor.
I use Windows 10. When I click "start" > "Cadence", there is only the "Licence Client Configuration Utility" available and nothing else. So I click an enter my host name with the port. But nothing happens, the padstack editor doesn't show up.
Do you know why ?
  • Reply
  • steve
    steve 7 days ago in reply to Joel88 +1
    Ok looks like the start menus weren't built as part of the installation. You can try using this link http://www.mediafire.com/file/j3flbh11aqcjunb/Cadence_PCB_174_StartMenuItems.zip/file to download...
  • steve
    steve 7 days ago
    Padstack Editor is under the Start menu Cadence PCB Utilities 17.4-2019 not Cadence so give that a try. You could also try typing Padstack Editor in the Type here to search for Windows 10 which should locate the app for you
    • Up 0 Down
    • Reply
  • Joel88
    Joel88 7 days ago in reply to steve
    I don't have Cadence Utilities 17.4-2019 showing up in the Start menu.
    There is orcad but no padstack editor in it. When I search for padstack editor in the search menu I find nothing.
    • Up 0 Down
    • Reply
  • steve
    to download the start menu shortcuts. Once downloaded unzip this to C:\Users\username\AppData\Roaming\Microsoft\Windows\Start Menu\Programs. The alternative is a full uninstall / reinstall
    • Up +1 Down
    • Reply
  • Joel88
    It worked, thanks a lot Steve.
    • Up 0 Down
    • Reply
