  3. Any Way to identify double hits (Via)?
  • Replies 36
  • Subscribers 168
  • Views 48959
Alice
Alice over 16 years ago
If  on the same net DRC, due to the stack via design. Alot of DRC will apply also.
Is there a way to identify this issue? Pls advice.
Alice
  • Romme
    Romme over 16 years ago
    Wouldn't it be easyer to setup drc rules to accept stacked via 's ?
  • Alice
    My problem is how to detect 2 same via overlap each other but has slight different xy position at same layer?
    These 2 vias have same net. So, if I on the same net drc, I will get alot of drcs.
  • Alice
  • eDave
    eDave over 16 years ago
    Hi Alice,
    Here's some code for you to try:
    defun( getDuplicateHoles (locs @key blindBuried, (tol axlMKSConvert(0.2 "mm")))
     let((loc, dupes)
      while(locs
        loc = car(locs), locs = cdr(locs)
        if(blindBuried then
          when(setof(pt, locs, and(cadr(pt) == cadr(loc), samePoint(car(pt), car(loc), tol)))
            dupes = cons(loc, dupes)
         else when(setof(pt, locs, samePoint(pt, loc, tol)), dupes = cons(loc, dupes))
      dupes
    defun( same (x1, x2 @optional tolp, tolm)
      unless(tolp, tolp = expt(10, -2 - cadr(axlDBGetDesignUnits())))
      cond(
        (!x1 && !x2, t); Both are nil
        (!x1 || !x2, nil) ; One, and only one, is nil
        (!tolm && abs(x1 - x2) > tolp, nil)
        (tolm && x1 - x2 > tolp, nil)
        (tolm && x2 - x1 > tolm, nil)
        (t, t)
    defun( samePoint (pt1, pt2, @optional tolp, tolm)
      and(same(car(pt1), car(pt2), tolp, tolm), same(cadr(pt1), cadr(pt2), tolp, tolm))
     Cheers, Dave
  • Marathon
    Marathon over 16 years ago
    Hi Dave,
    This is exactly the type of issue that I am trying to address - duplicate drills with the exact same xy and touching drills and then create a report file for them. Fab shops desire the report file so they can modify the NC drill file so not to make double or more hits on a single hole. Is it possible for you to expand on your code slightly to create a simple report file? The duplicate drills are also counted in the drill legend, but that is another issue.
    Much appreciated!
