  3. Any Way to identify double hits (Via)?
  • Replies 36
  • Subscribers 171
  • Views 53890
Alice
Alice over 17 years ago
If  on the same net DRC, due to the stack via design. Alot of DRC will apply also.
Is there a way to identify this issue? Pls advice.
Alice
  • Romme
    Romme over 17 years ago +1
    Wouldn't it be easyer to setup drc rules to accept stacked via 's ?
  • Alice
    Alice over 17 years ago +1
    My problem is how to detect 2 same via overlap each other but has slight different xy position at same layer? These 2 vias have same net. So, if I on the same net drc, I will get alot of drcs.
  • Alice
  • DE202408202727
    DE202408202727 over 17 years ago
    defun( getDuplicateHoles (objs @key (tol axlMKSConvert(0.2 "mm")))
     let((obj, loc, closeObjs, dupes, p)
      while(objs
        obj = car(objs), objs = cdr(objs), loc = obj ->xy
        closeObjs = setof(o, objs, and((car(o ->startEnd) == car(obj ->startEnd) || cadr(o ->startEnd) == cadr(obj ->startEnd)), samePoint(o ->xy, loc)))
        when(closeObjs
          dupes = cons(sprintf(nil, "%s at %L clashes with %s at %L", axlPPrint(obj ->objType), obj ->xy, buildString(unique(closeObjs ~>objType), ", "), closeObjs ~>xy), dupes)
      if(dupes then
        p = axlDMOpenFile("MISC", "duplicateHoles.txt", "w")
        fprintf(p, "Duplicate holes:\n\n")
        foreach(dupe, dupes, fprintf(p, "%s.\n", dupe))
        axlDMClose(p)
        axlUIViewFileCreate("duplicateHoles.txt", "Duplicate holes", nil)
       else
        println("No duplicates found.")
      dupes
    defun( same (x1, x2 @optional tolp, tolm)
      unless(tolp, tolp = expt(10, -2 - cadr(axlDBGetDesignUnits())))
      cond(
        (!x1 && !x2, t); Both are nil
        (!x1 || !x2, nil) ; One, and only one, is nil
        (!tolm && abs(x1 - x2) > tolp, nil)
        (tolm && x1 - x2 > tolp, nil)
        (tolm && x2 - x1 > tolm, nil)
        (t, t)
    defun( samePoint (pt1, pt2, @optional tolp, tolm)
      and(same(car(pt1), car(pt2), tolp, tolm), same(cadr(pt1), cadr(pt2), tolp, tolm))
  • Marathon
    Marathon over 17 years ago
    Hi Dave,
    Thanks for the reply. The code you provided obviously needs a list to process. I have been looking at that and am having some trouble with it.The list, I would assume would be from the xy locations from all the through hole pads and vias for a net. Each net would be processed individually instead of processing the entire xy locations for all the pads and vias from the entire design. This would report the “close holes” that we are really looking for otherwise they would have a DRC marker on them from the touching nets. Any thought on how to create the input list correctly?
  • DE202408202727
    defun( getDuplicateHoles (@optional netName)
     let((oldSetData, holeObjects)
      oldSetData = list(axlGetSelSet(), axlGetFindFilter(nil), axlGetFindFilter(t))
      axlClearSelSet()
      axlSetFindFilter(?enabled '("noall", "pins", "vias", "invisible"), ?onButtons '("noall", "pins", "vias"))
      axlAddSelectAll()
      holeObjects = setof(obj, axlGetSelSet(), obj ->isThrough)
      when(netName, holeObjects = setof(obj, holeObjects, obj ->net ->name == upperCase(netName)))
      axlSetFindFilter(?enabled cons("noall", cadr(oldSetData)) ?onButtons cons("noall", caddr(oldSetData)))
      axlSingleSelectObject(car(oldSetData))
      getDuplicateObjects(holeObjects)
    defun( getDuplicateObjects (objs @key (tol axlMKSConvert(0.2 "mm")))
      while(objs
        when(closeObjs
      if(dupes then
        axlDMClose(p)
       else
      dupes
      cond(
        (t, t)
    Someone owes me a beer!
  • Marathon
    Thanks Dave! I will ship you a case. Name your brand :)
    I will look closer as to why the report only finds pins that have the exact same xy and not ones that are slightly overlapped. Vias are also not found, but it is a tremendous start!
    Much appreciated!
  • DE202408202727
    Free stuff always has bugs;)
    I'd forgotten the tolerance. Here's the corrected function:
      while(objs
        closeObjs = setof(o, objs, and((car(o ->startEnd) == car(obj ->startEnd) || cadr(o ->startEnd) == cadr(obj ->startEnd)), samePoint(o ->xy, loc, tol)))
        when(closeObjs
      if(dupes then
        axlDMClose(p)
       else
      dupes
